Inbound rules
Discussion in 'Ideas' started by newmiracles, Nov 28, 2016.
Inbound rules 5 5 5votes
5/5, 5 votes
  1. newmiracles
    Aug 31, 2011
    6
    In V14 we were able to add DID's via the inbound rules the Check which trunks used the DID's, For Large deployment this is critical.
    In V15 DID are added to the trunk then to the inbound rule. This takes much longer and this was much easier in V14
  2. geracilaw
    Nov 30, 2016
    6
    This would be great feature to have, We have 250 Toll Free Numbers and it will be time consuming to taking additional steps.
  3. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    192
    66
    Version migration to V15 breaks a lot - esp DIDs. We have gotten into the practice of doing separate exports for the DIDs and EXTs . The DID's can be imported by taking the header from a sample export on V15 and inserting at the top of the V14 export. Not a lot of fun, but it works...
