Inbound Rules
Discussion in '3CX Phone System - General' started by Niconutter, May 8, 2008.
  1. Niconutter
    Mar 28, 2008
    11
    It’s possible configurations of inbound rules?
    IF the call it´s from Italy go to extension 101
    If the call it´s from Spain go to extension 102
    Thanks.
    NicoNutter
  2. coelhopsi
    May 7, 2008
    84
    There's currently no Inbound Routes feature in 3CX. However, you could try to do what you want using a combination of DID/DDI rules and configuring "Gateway / Provider Inbound Parameters" on the VoIP line settings to replace the "To : User Part" SIP field with the value of the "CallerNum". That would foul the 3CX into thinking that the To: field is actually the From: field and the DID rules would then transfer the call accordingly.
    This is just theory however, I've never tried it. You could give it a try and let us know if it works.
