Inbound Skype Works, Outbound Does Not
Discussion in '3CX Phone System - General' started by slm72, Oct 22, 2009.
  1. slm72
    Sep 21, 2009
    11
    Inbound calls from Skype work fine, but get "destination is not available, not registered, or no routes available". Here is the log...
    15:49:26.708 [CM503008]: Call(20): Call is terminated
    15:49:21.364 [CM503007]: Call(20): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=d6265902b6addd0c
    15:49:21.364 [CM503007]: Call(20): Device joined: sip:111@192.168.1.53:1173;rinstance=b61bae31d9bf70c0
    15:49:21.364 [CM503002]: Call(20): Alerting sip:EndCall@127.0.0.1:40600;rinstance=d6265902b6addd0c
    15:49:21.161 [CM503025]: Call(20): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=d6265902b6addd0c]
    15:49:21.145 [CM503016]: Call(20): Attempt to reach <sip:6304769400@192.168.1.22:5060> failed. Reason: Temporarily Unavailable
    15:49:21.145 [CM503003]: Call(20): Call to sip:304769400@127.0.0.1:6062 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6062
    15:49:21.145 [CM505002]: Gateway:[Skype1] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] PBX contact: [sip:10001@127.0.0.1:5060]
    15:49:21.145 [CM503002]: Call(20): Alerting sip:10001@127.0.0.1:6062;rinstance=59931b33e6fe96b1
    15:49:20.989 [CM503025]: Call(20): Calling PSTNline:304769400@(Ln.10001@Skype1)@[Dev:sip:10001@127.0.0.1:6062;rinstance=59931b33e6fe96b1]
    15:49:20.942 [CM503004]: Call(20): Route 1: PSTNline:304769400@(Ln.10001@Skype1)@[Dev:sip:10001@127.0.0.1:6062;rinstance=59931b33e6fe96b1]
    15:49:20.942 [CM503010]: Making route(s) to <sip:6304769400@192.168.1.22:5060>
    15:49:20.942 [CM505001]: Ext.111: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 4.0.9441.0] PBX contact: [sip:111@192.168.1.22:5060]
    15:49:20.927 [CM503001]: Call(20): Incoming call from Ext.111 to <sip:6304769400@192.168.1.22:5060>
    15:48:57.909 [CM503007]: Call(19): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=d6265902b6addd0c
    15:48:57.909 [CM503002]: Call(19): Alerting sip:EndCall@127.0.0.1:40600;rinstance=d6265902b6addd0c
    15:48:57.690 [CM503016]: Call(19): Attempt to reach <sip:6304769400@192.168.1.22:5060> failed. Reason: Temporarily Unavailable
    15:48:57.690 [CM505002]: Gateway:[Skype1] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] PBX contact: [sip:10001@127.0.0.1:5060]
    15:48:57.534 [CM503025]: Call(19): Calling PSTNline:304769400@(Ln.10001@Skype1)@[Dev:sip:10001@127.0.0.1:6062;rinstance=59931b33e6fe96b1]
    15:48:57.487 [CM503010]: Making route(s) to <sip:6304769400@192.168.1.22:5060>
    15:48:57.471 [CM503001]: Call(19): Incoming call from Ext.111 to <sip:6304769400@192.168.1.22:5060>
    15:19:12.019 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 69.0.208.27:3478 over Transport 192.168.1.22:5060
    14:39:11.840 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 69.0.208.27:3478 over Transport 192.168.1.22:5060
    14:10:35.613 [CM503008]: Call(18): Call is terminated
    14:10:31.285 [CM503007]: Call(18): Device joined: sip:111@192.168.1.53:1173;rinstance=b61bae31d9bf70c0
    14:10:31.098 [CM503025]: Call(18): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=d6265902b6addd0c]
    14:10:31.082 [CM503003]: Call(18): Call to sip:304769400@127.0.0.1:6062 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6062
    14:10:31.082 [CM503002]: Call(18): Alerting sip:10001@127.0.0.1:6062;rinstance=59931b33e6fe96b1
  2. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    Hi, this number 304769400 is incorrect.
    Skype requires international format of dialing number. You should dial +304769400 or 00304769400. If outbound rule prefix is (6) then you should dial 6+304769400 or 600304769400. + is equal to 00.
