inbounds calls show failed in logs.
Discussion in '3CX Phone System - General' started by Mirzab, Sep 18, 2007.
  1. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Left side menu on Admin page - Lines >> Manage - clicking on a line under "Identification" column gives different options compared to selecting same line under "Gateway/Provider Name" column. I believe you are seeking settings available under the latter column.
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    That is certainly your choice, 3CX is not mandatory. My personal opinion - nothing better unless you spend major dollars, and even then I would debate it. Maybe give it a try again after another month, v4 should be out then. I do love it myself, have it running trouble free in two locations.
