Inbund Caller ID Issue**E164 CONFIGURATION REQUIRED
Discussion in '3CX Phone System - General' started by ivan308, May 9, 2011.
  1. ivan308
    May 9, 2011
    6
    With the default Inbound Parameters I have an issue with Inbound Caller ID with Unknown Name and Unknown Number showing on the analog phone display connected to a Grandstream HT-268 and 5060;nf=e showing up on X-lite 4.
    I was able to get CallerName to show the number by setting P-Asserted Identity : User Part to CallerName and it appears as +1321xxxxxxx. Still get Unknown Number showing so it looks like the system is only populating CallerName and not CallerNum.
    Could it be because there is a + before the number and hence cannot be populated into a numeric field ?
    VOIP provider is Flowroute.
    Please see below for verbose log of call.
    Is there anyway to debug and see the value of variables ?
    Code:
    23:27:39.441  Currently active calls - 1: [38]
    23:27:38.994  [CM503025]: Call(38): Calling Ext:Ext.5150@[Dev:sip:5150@68.205.9.72:42908]
    23:27:38.990  [MS210002] C:38.2:Offer provided. Connection(transcoding mode): 209.114.198.38:10152(10153)
    23:27:38.908  [CM503004]: Call(38): Route 1: Ext:Ext.5150@[Dev:sip:5150@68.205.9.72:42908]
    23:27:38.906  [CM503010]: Making route(s) to <sip:5150@209.114.198.38:5060>
    23:27:38.905  [MS210000] C:38.1:Offer received. RTP connection: 4.55.17.2:12824(12825)
    23:27:38.902  Remote SDP is set for legC:38.1
    23:27:38.901  [CM505003]: Provider:[FlowRoute] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:58517501@209.114.198.38:5060]
    23:27:38.887  [CM503001]: Call(38): Incoming call from +13214800086@(Ln.10003@FlowRoute) to <sip:5150@209.114.198.38:5060>
    23:27:38.799  [CM503012]: Inbound any hours rule (*) for 10003 forwards to DN:5150
    23:27:38.798  Looking for inbound target: called=+13216043023; caller=+13214800086
    23:27:38.793  [CM500002]: Info on incoming INVITE:
      INVITE sip:13216043023@209.114.198.38:5060 SIP/2.0
      Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKaeda.509776d0495dfb7d6a9c0a6069fac054.0
      Via: SIP/2.0/UDP 216.115.69.131;branch=z9hG4bKaeda.c65f2305609bd0634567c4ae1c2b3fa4.0
      Via: SIP/2.0/UDP 216.115.69.132;branch=z9hG4bKaeda.4a737d8b85181dcca657981aa718cb1c.0
      Via: SIP/2.0/UDP 4.55.17.35:5060;branch=z9hG4bK0bB92aa1d9fa5e086dd
      Max-Forwards: 90
      Record-Route: <sip:216.115.69.144;lr>
      Record-Route: <sip:216.115.69.132;lr>
      Contact: <sip:+13214800086@4.55.17.35:5060>
      To: <sip:+13216043023@216.115.69.132:5060>
      From: <sip:+13214800086@4.55.17.35:5060>;tag=gK0b14ecdb
      Call-ID: 1678476564_109103228@4.55.17.35
      CSeq: 16968 INVITE
      Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay, multipart/mixed
      P-Asserted-Identity: <sip:+13214800086@pstn>
      Content-Length: 0
    23:27:09.429  Currently active calls [none]
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Re: Inbund Caller ID Issue
    Yes, '+' can be an issue. Enable E.164 preprocessing to eliminate it.
