Include date, not number, in scheduled backup file names
Discussion in 'Ideas' started by mcbsys, Apr 1, 2017.
Include date, not number, in scheduled backup file names 5 5 8votes
5/5, 8 votes
  1. mcbsys
    mcbsys New Member
    Oct 8, 2008
    191
    17
    The current 3CX backup naming convention for scheduled backups requires renaming all backup files every day.
    When backed up to Google drive, this causes two problems (originally reported here):
    - Google Drive updates the file date on rename, so every file has the same timestamp, making it difficult to find the backup from a specific date.
    - The multiple rename sequence fails about once a week, leaving backup names on Google Drive in a corrupt state.
    The simplest solution to both issues would be to include the date in the backup name, e.g. "3CXScheduledBackup.20170322.zip", then never rename it. Deleting the oldest file only requires listing alphabetically and deleting the first one.
  2. Buya
    Mar 6, 2018
    13
    Clearly, +1, we need this tiny feature.
    Thank you !
