Include Instance Name in Alerts
Discussion in 'Ideas' started by DSXDATA, Dec 7, 2015.
  1. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    185
    64
    In V14 (unlike V12) an alert does not specify the instance which is triggering the alert. For example, when an alert comes in saying that Extension 101 is unregistered there is no way of knowing which of the 20+ instances it came from on a CloudPBX. Currently the only solution to this is to edit the FROM field in every email template on every pbx.
  2. Anonymous
    Anonymous Guest
    Just like SBC status and/or any other cloud-system status, This is a must. 3cx is pushing for its channel to build cloud infrastructures. We need to tools to properly manage it.
