Include PIN Set Option for Selected Outbound Routes
Discussion in 'Ideas' started by Jose Lara, Sep 8, 2017.
  1. Jose Lara
    Mar 16, 2017
    23
    for Elastix Users and Administrator, the use Pin Set for Outbound routes is very usefull, I really think this can be great tool for 3CX Call Control
  2. Luis Monterroso
    Jul 12, 2017
    I agree. In Latin America is very frequent the use of Pin Set and we are loosing opportunities with financial institutions due to the absence of this feature.
  3. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    646
    110
    Take a look at our 3CX Enhanced Billing Codes. It sounds like this will meet your needs if I understand your requirements. 3CX already has a great tool for associating account codes with outbound calls, but the account codes are optional, and no verification that the account code is valid is provided. Our solution "requires" an account code to make certain types of calls. When you setup the account code, you also can restrict the type of calls that can be made with this account code. For example, you might have an account code that must be used to make international phone calls. Further, we verify whether the account code entered is valid. In other words, we enforce the use of an account code (PIN code) to make a call, and we keep track of the cost of that call too for reporting purposes, or for charging back the cost of the call to the department. https://www.VoIPTools.com
