Implemented Include SMTP settings in the backup
Discussion in 'Ideas' started by cobaltit, May 19, 2016.
  1. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,766
    277
    It would be nice if the 3CX backup included the SMTP settings in the backup/restore process.
