incoming and outgoing skype calls
Discussion in '3CX Phone System - General' started by jwnesbitt, Sep 28, 2009.
  1. jwnesbitt
    Sep 19, 2009
    48
    HI
    Looking for some info on using 3cx with Skype.
    Question 1 -
    I have setup the Skype gateway, and incoming Skype calls work OK, but all route to the same phone no matter which skype ID is called. I have setup 3 skype accounts on the machine where 3CX is installed, one for myself, my wife and my son. all incoming skype calls just get routed to her phone.
    Question 2 -
    How do I set the gateway / Outbound rule so that if user 1 dials a Skype ID, it gets routed via the Skype Gateway ?
    I have set a rule as follows
    dial 514
    drop 3 digits
    prepend with the specific skype id that i have associated with the number 514.
    This works fine, but only works with numbers that I manually associate with an ID.
    Is there a way of automating the procedure ?
    If i set the rule as follows
    dial 6skypename
    drop 6
    route via Skype gateway
    I get "called number does not exist"
    Jody
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,416
    61
    Hi, Jody
    For question 1:
    in the PBX PSTN settings, check if each is routed to the proper phone (say 101, 102, 103). If these are left default, they route incoming calls to the same phone, say 101.
    Regards
    vali
  3. jwnesbitt
    Sep 19, 2009
    48
    Great, thanks,
    incoming now working fine, It was routing to the Master account which i have now disabled
    just outgoing that I cant get my head around.
    Jody
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Please specify how do you dial the number and what is the number you are expecting to reach. Also add the logs of "Skype gateway".
  5. jwnesbitt
    Sep 19, 2009
    48
    hi
    I am trying to dial a Skype ID, not a number
    I started a new post for the outgoing skype calls with images of my rules
    http://www.3cx.com/forums/how-do-i-make-skype-to-skype-calls-through-skype-gateway-11670.html
    thanks
    Jody
  6. Vali_3CX
    Dec 12, 2008
    1,416
    61
    Hi, Jody
    Jody, before asking for tracelogs - what's happen if you try to call Skype's sound service, echo123? It's the first, basic test for outbound call, after setting-up the gateway.
    Regards
    vali
  7. jwnesbitt
    Sep 19, 2009
    48
    Please see this post for images of my outbound rule setup
    If I call a skype user by manually defining a number and prepending with the code and then dropping the number, it works fine
    If i try and use say 6 as a prefix, then it just does not dial
    Jody
  8. jwnesbitt
    Sep 19, 2009
    48
    Just to say this is now working
    Thanks to Steve Corrigan from 3Cx who pointed me in the right direction
    Had to make outgoing rule with
    a,b,c,d,e,f,g,h,i,j,k,l,m,n,o,p,q,r,s,t,u,v,w,x,y,z
    as the prefix range
    Jody
