Incoming Audio
Discussion in '3CX Phone System - General' started by mv.ape, Feb 26, 2015.
  1. mv.ape
    Feb 16, 2015
    24
    When I call from inside no problem, but when I receive a call from external I've no audio.
    I've try to check/uncheck PBX deliver audio no change.
    Any idea?
    10,375
    231
    You've provided very little information to go on.
    Depending on the method that you receive "outside" calls, it could be the port forwarding setting in your router or firewall programme. It could be settings on your gateway. It could be a Codec issue.
    The 3CX server log might provide some guidance, if it shows any errors during the establishment of a call.
    Did this issue just begin, or is this a new install? What about placing outside calls, is there audio?
  3. mv.ape
    Feb 16, 2015
    24
    No problem with outside call.
    Firewall checker is ok.
    I found this entry in log:
    some of SIP/SDP headers contain inconsistent information or modified
  4. leejor
    10,375
    231
    What type of trunking are you using? Do you have a second trunk group to do testing on? A number of provider will let you send them toll-free numbers (1800) for no charge or registration required, this could be used to confirm it isn't a problem with just one provider?
    Is your Public IP static or dynamic?
    Is this a "new" problem, or has it never worked?
    What type of router/firewall are you using?
  5. mv.ape
    Feb 16, 2015
    24
    I'm using a Trunk SIP and that work before (i don't know how much time that doesn't work anymore, it's a pre-preduction plateform).
    I'm using public adress IP behind an UTM Netasq. I've checked firewall log and nothing it's blocked.
    I've restarted services,
    I've desactived SIP inspection on UTM and it's seems to work.
