Incoming Call Authentication
Discussion in '3CX Phone System - General' started by soliduptime, Sep 8, 2011.
  1. soliduptime
    Sep 8, 2011
    Hi All,
    I have a client who wants to do something like this ... does anyone have any ideas of 3CX support incoming pin number authentication?
    Thanks in advance for any help
    The plan was as follows:
    Incoming call goes to message: (digital recpetionist).
    Press 1 for hardware support press 2 for Software support....
    On press 2: Please enter your pin number
    Correct pin..... > goes to certain extension
    or incorrect pin – message saying no support then to voice mail then email to everybody
    On press 1: Please enter your pin number
    Correct pin > route to appropriate person
    Incorrect pin: – message saying no support then to voice mail then email to everybody.
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Yes this is possible with the VAD. Check out information on the VAD on the blog http://www.3cx.com/blog
    Thanks,
    Nate
  3. soliduptime
    Sep 8, 2011
    Nate, thanks, I've actually just downloaded the VAD and am having a play with it at present, but not sure if it will work with the free version?
