Solved Incoming call display format
Discussion in '3CX Phone System - General' started by Helmut72, Oct 27, 2017.
  1. Helmut72
    Aug 24, 2017
    13
    when call come in the client shows callingnumber:destination number. How can I change this so only the calling number is displayed?
    Thank you!
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @Helmut72
    You can change this by navigating to Contacts / Options and under "Add Group, Queue or DID/DDI Names to Caller ID" option select Do not add. Let us know if that worked
  3. Helmut72
    Aug 24, 2017
    13
    Worked, thank you. I couldn't find anything in the manual about this feature, what is the use case to append / prepend DID/DDI as it breaks displaying names correctly.
  4. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    106
    38
    Naming the ring group or inbound rule will make that show up on the phone display. This is useful for clients with phones that are a member of more than one department or business.
    YiannisH_3CX likes this.
