Incoming Call issue
Discussion in 'Windows' started by iperez_genius, Jul 15, 2008.
  1. iperez_genius
    Jul 1, 2008
    56
    So i finally got the incoming call thing working and the pstn line is directed to a voice mail of extension 1207
    this is the logg i recieve on connection between my mobile and the phone line
    12:19:14.958 Call::Terminate [CM503008]: Call(19): Call is terminated
    12:19:14.911 Call::Terminate [CM503008]: Call(19): Call is terminated
    12:19:14.879 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10003 forwards to VM:1207
    12:19:12.208 CallCtrl::eek:nLegConnected [CM503007]: Call(19): Device joined: sip:9999@127.0.0.1:40600;rinstance=f16d066cfa08783c
    12:19:12.208 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10003 forwards to VM:1207
    12:19:12.161 CallCtrl::eek:nLegConnected [CM503007]: Call(19): Device joined: sip:10003@192.168.43.222@192.168.43.3:5060
    12:19:12.146 Extension::printEndpointInfo [CM505001]: Ext.9999: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] Transport: [sip:127.0.0.1:5060]
    12:19:12.146 CallCtrl::eek:nAnsweredCall [CM503002]: Call(19): Alerting sip:9999@127.0.0.1:40600;rinstance=f16d066cfa08783c
    12:19:11.614 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(19): Calling: Ext:Ext.9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=f16d066cfa08783c]
    12:19:11.614 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:1207@sip.mydomain.com:5060;user=vmail]
    12:19:11.614 Line::printEndpointInfo [CM505002]: Gateway:[DDpstnLine] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3000-3.1.10(GWd)] Transport: [sip:192.168.43.222:5060]
    12:19:11.614 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10003 forwards to VM:1207
    12:19:11.521 CallCtrl::eek:nIncomingCall [CM503001]: Call(19): Incoming call from 10003@(Ln.10003@DDpstnLine) to [sip:1207@sip.mydomain.com:5060;user=vmail]
    12:19:11.521 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10003 forwards to VM:1207
    Can anyone shed some light
    Ilan
  2. Henk
    Henk Member
    Nov 13, 2007
    250
    Question:
    When you not using voice mail, do you still get this error?
    H.
  3. iperez_genius
    Jul 1, 2008
    56
    i changed the pstn line to direct calls to the extension 1207...not the voicemail.
    Firstly the connection just rang and rang. I couldn't actually pick up the phone. Secondly if you look at the server status you will see that the call terminates twice...actually it terminates many times, i am only showing you the status twice.
    15:14:38.405 Call::Terminate [CM503008]: Call(24): Call is terminated
    15:14:38.359 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10003 forwards to DN:1207
    15:14:36.281 Extension::printEndpointInfo [CM505001]: Ext.1207: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.43.222:5060]
    15:14:36.281 CallCtrl::eek:nAnsweredCall [CM503002]: Call(24): Alerting sip:1207@192.168.43.2:5070;rinstance=9c02cd380d065b51
    15:14:35.703 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(24): Calling: Ext:Ext.1207@[Dev:sip:1207@192.168.43.2:5070;rinstance=9c02cd380d065b51]
    15:14:35.703 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:1207@sip.mydomain.com:5060]
    15:14:35.703 Line::printEndpointInfo [CM505002]: Gateway:[DDpstnLine] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3000-3.1.10(GWd)] Transport: [sip:192.168.43.222:5060]
    15:14:35.687 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10003 forwards to DN:1207
    15:14:35.609 CallCtrl::eek:nIncomingCall [CM503001]: Call(24): Incoming call from 10003@(Ln.10003@DDpstnLine) to [sip:1207@sip.mydomain.com:5060]
    15:14:35.609 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10003 forwards to DN:1207
    15:14:34.812 Call::Terminate [CM503008]: Call(23): Call is terminated
    15:14:34.766 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10003 forwards to DN:1207
    15:14:30.532 Extension::printEndpointInfo [CM505001]: Ext.1207: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.43.222:5060]
    15:14:30.532 CallCtrl::eek:nAnsweredCall [CM503002]: Call(23): Alerting sip:1207@192.168.43.2:5070;rinstance=9c02cd380d065b51
    15:14:30.032 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(23): Calling: Ext:Ext.1207@[Dev:sip:1207@192.168.43.2:5070;rinstance=9c02cd380d065b51]
    15:14:30.032 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:1207@sip.mydomain.com:5060]
    15:14:30.032 Line::printEndpointInfo [CM505002]: Gateway:[DDpstnLine] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3000-3.1.10(GWd)] Transport: [sip:192.168.43.222:5060]
    15:14:30.032 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10003 forwards to DN:1207
    15:14:29.954 CallCtrl::eek:nIncomingCall [CM503001]: Call(23): Incoming call from 10003@(Ln.10003@DDpstnLine) to [sip:1207@sip.mydomain.com:5060]
    15:14:29.938 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10003 forwards to DN:1207
    Henk...
    any ideas
  4. Henk
    Henk Member
    Nov 13, 2007
    250
    No idea as yet,
    Question:
    Extension 1207, you can make and receive calls with that extension locally eg extension to extension dialing?
    H.
  5. iperez_genius
    Jul 1, 2008
    56
    yep,
    no problems
