Incoming Call makes 3cx Crash
Discussion in 'iOS' started by salomon, Aug 5, 2011.
  1. salomon
    Aug 5, 2011
    Hello Stefan,
    I have installed 3cx on 2 iphones 3 and 4 respectively.
    Both of them are configured to a Voipswitch,
    Both of them Crash when Incoming call comes
    Data : Iphone 3 :
    IoS Version: 4.3.5 (8L1)
    NO Cracks or HAcks installed
    NEtwork 3G/WIFI
    Iphone 4
    IOS Version 4.3.3 (8J2)
    NO Cracks or HAcks Installed
    Network 3G/WIFI
    On Both iphones have tried to turn off Multitasking, with same result,
    Both of them are capable to originate calls
    Both of them have been tested as well on 3G and WIFI
    Both of them 3CX Crashes when incoming call.
    If you reboot the Iphone and send an incoming call after 3CX registers on voipswitch, you can hear the first tone
    of the incoming call and then it will crash. any other attempt, will just crash the application.
    On the Iphone 3 today I uninstalled 3CX, rebooted, and downloaded 3cx and installed again, with exactly same results.
    Note, when using 3CX on my pc , it works 100% ok, it sends and receives calls from Voipswitch.
    Thanks for your soon comments
    Salomon
  2. StefanW
    Jun 2, 2009
    1,163
    74
    Hello Salomon,
    have you very tried it on a 3CX PBX?
    May we receive an Invite from you PBX which is for us Maleformatet or has an unneeded reinvite after the call.
    Check out our PBX here: http://www.3cx.com/ip-pbx/downloadlinks.html
    and compare the invite structure of them both pbx systems.
  3. cabco
    Jun 17, 2010
    7
    I have the exact same problem on 3CX using 3CX app for iPhone with ios higher than 4.2.1.
    Very frustrating!
  4. willow
    willow Member
    Mar 1, 2011
    471
    the 3cx softohone app was really designed to work in conjuction with a 3cx server. I am really not surprised that you would having issues connecting to a 3rd party switch or service provider. It is not meant to do such things. I use it with a 3cx server and have quite a few customers that using it with their 3cx servers and have very little issues besides some software limitations that are being worked out.
  5. cabco
    Jun 17, 2010
    7
    Hi Willow,
    I am actually using it in conjunction with a 3CX server. All 3CX products but seemingly incompatible with iOS 4.3+
  6. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,416
    58
    Wait a little for the newest version - not only it embeds the 3CX tunnel, but is much improved and stable compared with the current release.
