incoming call no audio
Discussion in '3CX Phone System - General' started by ksantella, Sep 20, 2007.
  1. ksantella
    Apr 23, 2007
    I had this issue before and was resolved when I loaded previous version. I loaded new version (2434) and I got it again. Here is what happens.
    Incoming calls no audio. If I place the call on hold then pick it up again the audio is there until 30 seconds when the call drops. I will place my firewall / NAT settings but this has not been changed. One thing I notice is that my STUN used to resolve to address:5060 now its a number in the 10000's. Also, I am getting Cant send RTP stream to
    All outgoing calls work well. I have listed below my firewall settings followed by logs of one incoming and one outgoing call for review. Thanks for the help.
    # Service Name Start Port End Port Server IP Address
    1 VOIP-TFTP 69 69
    2 VOIP-SIP 5060 5061
    3 VOIP-RTP 8000 9998
    4 PBX 5480 5482
    5 VOIP-STUN 3478 3478
    6 VOIP-INTERNAL 7000 7500
    7 VOIP_VOICE 10000 20000
    outgoing call and STUN
    09:02:22.328 StunClient::process [CM115002] STUN resolved external IP= by server
    08:57:53.156 StratInOut::eek:nHangUp [CM104007] Call(32): Call from Ext.301 to 17325171151 has been terminated by Ext.301; cause: CANCEL; from IP:
    08:57:21.562 CallConf::eek:nProvisional [CM103003] Call(32): Ln:10000@junction is ringing
    08:57:18.093 CallConf::eek:nIncoming [CM103002] Call(32): Incoming call from 301 (Ext.301) to sip:17325171151@
    incoming call
    08:49:45.781 MediaServerReporting::RTPReceiver [MS105000] Call(30) Ext.301: No RTP packets were received on 0000003B@:remoteAddr=,extAddr=,localAddr=
    08:49:45.765 StratLink::eek:nHangUp [CM104001] Call(30): Ext.301 hung up call; cause: BYE; from IP:
    08:49:45.640 CallLegImpl::eek:nConnected [CM103001] Call(30): Created audio channel for Ln:10000@junction ( with Media Server (
    08:49:45.625 StratInOut::eek:nConnected [CM104005] Call(30): Setup completed for call from Ext.301 to Ln:10000@junction
    08:49:45.625 CallLegImpl::eek:nConnected [CM103001] Call(30): Created audio channel for Ext.301 ( with Media Server (
    08:49:20.265 CallConf::eek:nProvisional [CM103003] Call(30): Ln:10000@junction is ringing
    08:49:17.843 CallConf::eek:nIncoming [CM103002] Call(30): Incoming call from 301 (Ext.301) to sip:17329270829@
  2. Urbok
    Urbok New Member
    Jul 14, 2007
    edit the extension and try to set the flag "is external" on the advanced option tab.
    let me know if this works.
  3. dete
    Sep 12, 2007
    I have the same Problem
    It happent only with the client that are over internet
