Incoming call rejected, caller is unknown
Discussion in '3CX Phone System - General' started by BobD, Jul 12, 2011.
  1. BobD
    Apr 25, 2011
    27
    I've got a Skype Connect trunk with 3 channels and 6 phone numbers. I can call in-out just fine but I'm unable to configure DID successfully. It seems like such a basic something but I'm getting busy when I call in from my cell (CCCCCCC) to my desktop (DDDDDDD). Suggestions?
    17:35:20.433 [CM502001]: Source info: From: <sip:1205CCCCCCC@sip.skype.com>;tag=ca90d13f-13c4-4e1ccc28-1f469596-3285feac<sip:1205DDDDDDD@sip.skype.com>
    17:35:20.433 [CM503013]: Call(9): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 1205DDDDDDD@192.168.2.90:5060 tid=-8133-4e1ccc28-1f469596-7bae0775 cseq=INVITE contact=1205CCCCCCC@63.209.144.201:5060 / 1 from(wire)
    17:35:20.429 [CM500002]: Info on incoming INVITE:
    INVITE sip:1205DDDDDDD@192.168.2.90:5060;rinstance=b41a53f764696fa5;transport=udp SIP/2.0
    Via: SIP/2.0/UDP 63.209.144.201:5060;branch=z9hG4bK-8133-4e1ccc28-1f469596-7bae0775
    Max-Forwards: 30
    Contact: <sip:1205CCCCCCC@63.209.144.201:5060;transport=udp>
    To: <sip:1205DDDDDDD@sip.skype.com>
    Call-ID: CXC-976-62283dd0-ca90d13f-13c4-4e1ccc28-1f469596-1d9094fe
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE
    User-Agent: SipGW 4
    Content-Length: 0
    17:35:20.120 [CM502001]: Source info: From: <sip:1205CCCCCCC@sip.skype.com>;tag=ca90d13f-13c4-4e1ccc28-1f469456-55b5874d<sip:1205DDDDDDD@sip.skype.com>
    17:35:20.120 [CM503013]: Call(8): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 1205DDDDDDD@192.168.2.90:5060 tid=-8131-4e1ccc28-1f469456-124202 cseq=INVITE contact=1205CCCCCCC@63.209.144.201:5060 / 1 from(wire)
    17:35:20.116 [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 63.209.144.201:5060;branch=z9hG4bK-8131-4e1ccc28-1f469456-124202
    Max-Forwards: 30
    Call-ID: CXC-761-62283a50-ca90d13f-13c4-4e1ccc28-1f469456-1b4d1a77
    CSeq: 1 INVITE
    User-Agent: SipGW 4
    Content-Length: 0
    Bob
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Seems you haven't configured your DDI numbers correctly.
    Look at: http://www.3cx.com/blog/docs/did-voip-provider/
    Regards
  3. BobD
    Apr 25, 2011
    27
    Thanks!
    That article was v9 but didn't take too much effort to convert to v10. No phones to test with from current site but log shows promise. :)
