Incoming Call --> TAPI --> CRM
Discussion in 'Windows' started by helmutsc, Dec 20, 2007.
  1. helmutsc
    Dec 20, 2007
    Hello!
    We can dial out by VoIP client throug TAPI from Outlook and from our CRM. But we dont get an incoming signaling to our CRM software. In this directon the CRM should open the cutomer data which is assigned to the incoming phone number.
    Should this feature alreday be available in the BETA 3?
    best regards
    Helmut
