Incoming call to extension based on caller id?
Discussion in '3CX Phone System - General' started by kungmats, Apr 3, 2010.
  1. kungmats
    Mar 30, 2010
    6
    Hi!
    Is it possible to route an incoming call to a specific extension based on the caller id?
    Lets say someone calls me from number 08123456 = route to ext 200
    Lets say someone calls me from number 08987654 = route to ext 201
  2. sipero123
    Nov 24, 2008
    94
    Yes this is quite easy to setup via the incoming call rules and if you have several DDIs from a single VOIP provider trunk you just need to configure this in 3CX so it knows to which extension these should be delivered.
    Jonathan Hamon
  3. kungmats
    Mar 30, 2010
    6
    Hmm ..... I only have 1 incoming provider ... is that possible to do that in that case?
    Can you please give me an example how/where to setup it?
  4. leejor
    11,263
    358
    Have all calls go to a dummy extension before defaulting to a ring group or DR. An extension, in Version 8 , has options to route/reject calls based on caller ID.
  5. kungmats
    Mar 30, 2010
    6
    Thanks! ... Good idea :)
