Incoming calls are being rejected!
Discussion in '3CX Phone System - General' started by twentydur, Oct 27, 2009.
  1. twentydur
    Oct 27, 2009
    Hi there,
    I've the following system:
    1. 3CX Phone System
    2. LinkSys 3102
    3. IP Phones
    4. PSTN Line
    Everything seems to work fine.
    IP Phones can make calls perfectly between them.
    IP Phones can make calls outside without a problem using the PSTN line attached to LinkSys 3102.
    BUT
    Incoming calls coming from PSTN line are being rejected by 3CX Phone System.
    I get the following messages at the 3CX server:
    16:47:11.740 [CM503008]: Call(44): Call is terminated
    16:47:11.740 [CM502001]: Source info: From: "Linksys SPA-3102"
    sip:10000@192.168.0.200>;tag=76d4748490166cb8o1<sip:10000@192.168.0.200>
    16:47:11.740 [CM503013]: Call(44): Incoming call rejected, caller is unknown; msg=SipReq:
    INVITE 10000@192.168.0.200 tid=-4fd301c4 cseq=INVITE contact=10000@192.168.0.201:5061 / 102 from(wire)
    Where
    192.168.0.200 is the 3CX IP
    192.168.0.201 is the LinkSys 3102 IP
    10000 is the LinkSys 3102 Virtual Extension
    Why is the call being rejected?
    Do I have to specify which callers are able to call? Where at?
    I've routed all the incomming calls from port 10000 to the Digital Receptionist (ext.100).
    Is it possible to create an Inbound Rule for all incoming calls? I've created the following one:
    DIDNumber: *
    Port Identification: 10000
    Associated Port Identification: 10000
    During Office Hours / Out of Office Hours: 100 (Digital Receptionist)
    Any idea of why is 3CX refusing the calls?
    Thanks a lot!
    Juan Bravo.
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    When you say Digital Receptionist, you mean the IVR or the Operator Extension ( which is 100 )?
  3. twentydur
    Oct 27, 2009
    I've used the option:
    Connect to Digital Receptionist: [ 100 Digital Receptionist ]
    So the Virtual Extension is 100.
    Indeed, when any of the VoIP Phones dial 100# they go directly to the Digital Receptionist without problem.
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    In the 3CX settings for gateway find tab 'Inbound parameters' and add source identification rule, where RequestLine:User matches $LineId. that's it.
