Incoming calls are not conencted
Discussion in '3CX Phone System - General' started by mchristsen, Jul 10, 2012.
  1. mchristsen
    Mar 30, 2010
    26
    Hello
    We just upgraded from V10 to V11 by way of a restore of the V10 configuration.
    All seems normal, however any call from the phone to voicemail or an incoming call to the digital assistant is resulting in a "This call cannot be completed, please try again..."
    Below is an example of the log of an extension trying to call 999 for voicemail.
    Please advise.
    We are thinking of rolling back to V10.
    10-07-2012 09:05:45.719 Leg L:1.1[Extn] is terminated: Cause: 200 BYE from PBX
    10-07-2012 09:05:45.719 [CM503008]: Call(C:1): Call is terminated
    10-07-2012 09:05:45.714 Leg L:1.2[VMail] is terminated: Cause: 200 BYE "SIP" from 127.0.0.1:40600
    10-07-2012 09:05:37.114 [CM503007]: Call(C:1): VMail:999 has joined, contact <sip:999@127.0.0.1:40600>
    10-07-2012 09:05:37.113 [CM503007]: Call(C:1): Extn:102 has joined, contact <sip:102@172.24.19.82:5060>
    10-07-2012 09:05:36.962 [CM503025]: Call(C:1): Calling T:VMail:999@[Dev:sip:999@127.0.0.1:40600;rinstance=6f36c9a1037ce536]
    10-07-2012 09:05:36.924 [CM503027]: Call(C:1): From: Extn:102 ("Michael Christsen" <sip:102@172.24.14.10:5060>) to T:VMail:999@[Dev:sip:999@127.0.0.1:40600;rinstance=6f36c9a1037ce536]
    10-07-2012 09:05:36.924 [CM503004]: Call(C:1): Route 1: T:VMail:999@[Dev:sip:999@127.0.0.1:40600;rinstance=6f36c9a1037ce536]
    10-07-2012 09:05:36.923 [CM503001]: Call(C:1): Incoming call from Extn:102 to <sip:999@172.24.14.10:5060>
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,560
    301
    Do all of the services show as running?
  3. mchristsen
    Mar 30, 2010
    26
    Yes, all services are showing as running.
  4. mchristsen
    Mar 30, 2010
    26
    OK i figured it out. The 3CXApplicationPool in IIS was stopped. I started the Pool and all seems to be working. A review of the event viewer showed some ASP.NET unhandled exceptions in the IVR module.
    See Below.
    Log Name: Application
    Source: ASP.NET 4.0.30319.0
    Date: 7/10/2012 9:01:06 AM
    Event ID: 1309
    Task Category: Web Event
    Level: Warning
    Keywords: Classic
    User: N/A
    Computer: RPVDC.mobilexe.com
    Description:
    Event code: 3005
    Event message: An unhandled exception has occurred.
    Event time: 7/10/2012 9:01:06 AM
    Event time (UTC): 7/10/2012 4:01:06 PM
    Event ID: 0b325e0793c8429f8d48c7a9e0741296
    Event sequence: 9
    Event occurrence: 1
    Event detail code: 0
    Application information:
    Application domain: /LM/W3SVC/2/ROOT/ivr-5-129864096593857530
    Trust level: Full
    Application Virtual Path: /ivr
    Application Path: C:\ProgramData\3CX\Data\Http\Interface\ivr\
    Machine name: RPVDC
    Process information:
    Process ID: 4348
    Process name: w3wp.exe
    Account name: NT AUTHORITY\SYSTEM
    Exception information:
    Exception type: PhoneSystemException
    Exception message: Config server is not connected
    at TCX.Configuration.PhoneSystem.Connect()
    at TCX.Configuration.PhoneSystem.get_Root()
    at _Default.Page_Load(Object sender, EventArgs e) in c:\ProgramData\3CX\Data\Http\Interface\ivr\Default.aspx.cs:line 152
    at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
    at System.Web.UI.Control.LoadRecursive()
    at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
    Request information:
    Request URL: http://localhost:5000/ivr/ivr_start.aspx?IVRHandlerMENU=999&FromDispName=Michael Christsen&IVRHandlerFROM=102&IVRHandlerTO=999&ISID=From_102_To_999_Menu_999_#0/0
    Request path: /ivr/ivr_start.aspx
    User host address: 127.0.0.1
    User:
    Is authenticated: False
    Authentication Type:
    Thread account name: NT AUTHORITY\SYSTEM
    Thread information:
    Thread ID: 45
    Is impersonating: False
    Stack trace: at TCX.Configuration.PhoneSystem.Connect()
    Custom event details:
    Event Xml:
    <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
    <System>
    <Provider Name="ASP.NET 4.0.30319.0" />
    <EventID Qualifiers="32768">1309</EventID>
    <Level>3</Level>
    <Task>3</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2012-07-10T16:01:06.000Z" />
    <EventRecordID>9407</EventRecordID>
    <Channel>Application</Channel>
    <Computer>RPVDC.mobilexe.com</Computer>
    <Security />
    </System>
    <EventData>
    <Data>3005</Data>
    <Data>An unhandled exception has occurred.</Data>
    <Data>7/10/2012 9:01:06 AM</Data>
    <Data>7/10/2012 4:01:06 PM</Data>
    <Data>0b325e0793c8429f8d48c7a9e0741296</Data>
    <Data>9</Data>
    <Data>1</Data>
    <Data>0</Data>
    <Data>/LM/W3SVC/2/ROOT/ivr-5-129864096593857530</Data>
    <Data>Full</Data>
    <Data>/ivr</Data>
    <Data>C:\ProgramData\3CX\Data\Http\Interface\ivr\</Data>
    <Data>RPVDC</Data>
    <Data>
    </Data>
    <Data>4348</Data>
    <Data>w3wp.exe</Data>
    <Data>NT AUTHORITY\SYSTEM</Data>
    <Data>PhoneSystemException</Data>
    <Data>Config server is not connected
    </Data>
    <Data>http://localhost:5000/ivr/ivr_start.aspx?IVRHandlerMENU=999&amp;FromDispName=Michael Christsen&amp;IVRHandlerFROM=102&amp;IVRHandlerTO=999&amp;ISID=From_102_To_999_Menu_999_#0/0</Data>
    <Data>/ivr/ivr_start.aspx</Data>
    <Data>127.0.0.1</Data>
    <Data>
    </Data>
    <Data>False</Data>
    <Data>
    </Data>
    <Data>45</Data>
    <Data>False</Data>
    <Data> at TCX.Configuration.PhoneSystem.Connect()
    </Data>
    </EventData>
    </Event>
