Incoming calls don't display leading 0
Discussion in '3CX Phone System - General' started by roth, May 13, 2010.
  1. roth
    May 10, 2010
    13
    Our 3cx installation in the UK using a patton smartnode 4960 seems to strip off the leading 0 of the area code of the incoming calls caller id's making it more difficult to return missed calls using tools like call assistant. For example 01603xxxxxx is presented as 1603xxxxxx
    It would seem that this may be being done by the gateway as the first line in the server activity log with the number whna a call is made shows it woithout the leading 0. But I can't see any settings on the gateway that would cause this to happen.
    Any help would be much appreciated
  2. StefanW
    Jun 2, 2009
    1,222
    93
  3. roth
    May 10, 2010
    13
    Thanks all working now
