incoming calls fail with FXO line
Discussion in '3CX Phone System - General' started by Christophe, Jun 12, 2008.
  1. Christophe
    May 16, 2008
    hi everybody,
    I have a problem with the incoming calls.
    I use 3CX phone system with softphones and a vegastream gateway with FXS and FXO ports.
    external call pass but not internal call.
    I put a redirection on the extention 5020 (a 3CX voip client) in line configuration.
    here is the log of server :
    Heure Fonction Message
    12:07:04.140 evt::CheckIfAuthIsRequired::not_handled [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:0130627178@192.168.190.141:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.190.20:5060;branch=z9hG4bK-vega1-000A-F027-0007-652E1DAC
    Max-Forwards: 70
    Contact: [sip:0130627178@192.168.190.20:5060]
    To: [sip:0130627178@192.168.190.141]
    From: "FXO 1"[sip:0130627178@192.168.190.141];tag=0079-0004-1B2C9871
    Call-ID: 0078-0001-0B3A9B20-0@9916BB9C134DC576E
    CSeq: 61480 INVITE
    Accept-Language: en
    Allow: INVITE, ACK, BYE, CANCEL, INFO, NOTIFY, OPTIONS, REFER
    Supported: replaces, privacy
    User-Agent: VEGAEURO/13.02.08.1xS008
    Privacy: none
    P-Preferred-Identity: "FXO 1" [sip:0130627178@192.168.190.141]
    Content-Length: 0
    12:07:04.140 evt::CheckIfAuthIsRequired::not_handled [CM302001]: Authorization system can not identify source of: SipReq: INVITE 0130627178@192.168.190.141:5060 tid=-vega1-000A-F027-0007-652E1DAC cseq=INVITE contact=0130627178@192.168.190.20:5060 / 61480 from(wire)
    thanks for your help
    bye
  2. Christophe
    May 16, 2008
    well done
    I had to create and registrar the fxo port on the 3CX server.
    now, it works ^^
