incoming calls from MyDivert.com SIP number
Discussion in '3CX Phone System - General' started by philduv, Sep 4, 2010.
  1. philduv
    Aug 19, 2010
    12
    I didn't arrive to receive the calls from my DID number into my internal extension or call group.
    I create a new SDA with SDA mask *530, port of Mydivert providers, connected.
    I tried to connect the call to an extension, a group of calls.
    I tried *194 SDA mask also but nothing is ringing ...
    Here is the log:
    14:47:35.656 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:35220332530@85.94.224.10:23192;rinstance=8579356f27cfc180 SIP/2.0
    Via: SIP/2.0/UDP 188.40.93.13:5060;branch=z9hG4bK59cb.0344b1d3.0
    Max-Forwards: 69
    Contact: <sip:+352691187187@188.40.93.13:5060>
    To: <sip:35220332530@188.40.93.13:5060>
    From: "+352691187187"<sip:+352691187187@188.40.93.13>;tag=as455b22c8
    Call-ID: 291484de471735173c8d632262f915bd@188.40.93.13
    CSeq: 102 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
    Date: Sat, 04 Sep 2010 12:47:36 GMT
    Supported: replaces, timer
    User-Agent: Asterisk
    Content-Length: 0
    X-voipnow-did: 35220332530, 35220332530
    X-voipnow-extension: 001100194
    X-voipnow-infrastructureid: 0081b0675fcb
    X-voipnow-chargingid: 4hq52kdx
    14:47:35.656 [CM302001]: Authorization system can not identify source of: SipReq: INVITE 35220332530@85.94.224.10:23192 tid=59cb.0344b1d3.0 cseq=INVITE contact=+352691187187@188.40.93.13:5060 / 102 from(wire)
    Thanks for your help.
    Ph. Duvivier
    11,123
    330
    http://www.3cx.com/blog/docs/source-identification-issues/
  3. philduv
    Aug 19, 2010
    12
    Thank you Leejor, It's working fine!
    Kind Regards.
    Ph. Duvivier
