Incoming calls go ananswerd
Discussion in '3CX Phone System - General' started by stobby256, Sep 18, 2013.
  1. stobby256
    Sep 9, 2013
    27
    Hi All,
    3CX on server 2012, Grandstream 4104 gateway. Testing this lot on the bench... All extensions can ring each other OK... outgoing calls just fine !
    However incoming calls ring and ring... and in the server log I get :-
    <phone no. calling in> had no available outgoing trunk(s) for Call(31)
    Outgoing? all my calls are set to ring just one extension! I've played around with endless incoming rules etc but it makes no impact..
    Help before I go insane....
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Can you post the full logs so we can see whats going on?
  3. stobby256
    Sep 9, 2013
    27
    Thanks for the reply David..
    After much noodling I got it to work...
    As server 2012 has a diabolical 1024x768 only display, the options "allow incoming / outgoing calls" from this extension rolled off the bottom of the screen...
    <embarrassed>
    Please close the thread... :roll:
