Incoming calls going straight to voicemail
Discussion in '3CX Phone System - General' started by teldata1, Oct 24, 2016.
  1. teldata1
    Aug 24, 2015
    63
    I have a strange issue with one of the systems I manage. Basically more often than not, incoming calls that are supposed to go to a ring group, do not ring at the extensions in the group, but instead go directly to the digital receptionist.. if the user then dials an extension number, it will go directly to the voicemail of that user.
    Other times, only one out of the two extensions in the ring group will ring.
    Anyone else experience this?
  2. mortenjorge
    Apr 1, 2015
    59
    12
    Please provide logs from your activity log :)
    then i'll be happy to check it :)
  3. hogan71088
    Nov 30, 2015
    62
    I've experienced it but just with DDI's not a ring group. Never did get to the bottom of it it seemed to disappear.
  4. DBriggs
    May 28, 2017
    I'm new to the 3CX scene, sorry for the lack of knowledge here. I'm experiencing this on my initial voip setup, and am in hopes that by now, someone found a resolution. I don't have an extensive activity log to provide, since it's still in the setup mode for my client. 3CX version 15.5.
    Thank you kindly,
    D.
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,545
    298
    We would still need logs - turned on in verbose... restart the 3cx services. place a test call and capture the details of what is happening.
  6. DBriggs
    May 28, 2017
    First...thank you for stepping in to offer support/assistance, it's much appreciated! I know that it will be awhile before I'm proficient enough to be on the giving side. The good news is, I was able to resolve my issue. A bit of information concerning the sip trunk registration was not correct, causing the issue for me. Again, thank you! D.
  7. craigreilly
    Feb 1, 2012
    3,545
    298
    Strange behavior for a trunk reg issue.
