Incoming Calls Not Listed In Calllog - Motorola Cliq
Discussion in 'Android' started by sfire, Aug 7, 2010.
  1. sfire
    Jul 7, 2010
    9
    I'm hoping one of the developers will notice this.
    I'm loving 3CXphone and finally have everything working PERFECT. Well almost perfect.
    3CXphone isn't keeping a list of my missed calls in the call log. If they leave a voicemail obviously I know that they called however a lot of people just assume that their number is going to appear on the caller ID.
    The call logging works perfectly for outgoing calls. Is there any way to get this working for incoming calls?
    Is this specific to my phone or is everyone having this issue?
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,503
    99
    This is most probably specific to your phone.
    There's just 1 thing you can check by yourself in the phone settings.
    3CXPhone > Profile > Settings > Integration > Log Call records and make sure this option is enabled.
    Another thing you can try is it re-create the profile from scratch and see if this issue persists.
