Incoming calls rejected - build v6.1793
Jirka
Hi there,
can anybody help me I have tried to upgrade to v6.1793 and ever since that I have problem with incoming calls. See details in the log bellow.
I have used same set up for this provider in older version and that worked perfectly .
13:42:16.234 Call::Terminate [CM503008]: Call(1): Call is terminated
13:42:16.234 CallCtrl::eek:nIncomingCall [CM502001]: Source info: From: 1; To: "778xxxxxxx"[sip:[email protected]];tag=as2db36554[sip:[email protected]:5060;rinstance=251823215d70ed0b]
13:42:16.234 CallCtrl::eek:nIncomingCall [CM503013]: Call(1): Incoming call rejected, caller is unknown; msg=SipReq: INVITE [email protected]:5060 tid=65dd671f cseq=INVITE [email protected] / 102 from(wire)
Thanks a lot for your help Jirka.
This would require some detailed troubleshooting and thus to resolve this you need to contact our technical support (This requires commercial edition with support package).
If you have a commercial edition, but no support package, you can purchase one here:
https://erp.3cx.com/orderform/support.aspx
regards
I had similar problem went i upgraded from v5 to V6.
Check the Source Identification >> Match Any fields
This solved mine issue.
The problem solved, I have played around with Gateway / Provider Inbound Parameters and got it work. :p
Get 3CX - Absolutely Free!
3CX
