incoming calls sent to vmail after 1 ring
Discussion in '3CX Phone System - General' started by timbo_w, Aug 18, 2011.
  1. timbo_w
    Aug 18, 2011
    my incoming callas are cut off and the caller sent to vmail after 1 ring, is there something i am missing
    16:18:17.325 [CM503003]: Call(11): Call to sip:11@192.168.0.29:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.0.10:5060
    16:18:17.126 [CM503008]: Call(11): Call is terminated
    16:18:16.850 [CM503025]: Call(11): Calling Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:18:16.809 [CM503004]: Call(11): Route 1: Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:18:16.808 [CM503010]: Making route(s) to <sip:11@192.168.0.29:5060>
    16:18:16.805 [CM505003]: Provider:[VoipTalk - UK] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Asterisk PBX] PBX contact: [sip:844267727@93.152.95.165:5060]
    16:18:16.797 [CM503001]: Call(11): Incoming call from 07734104281@(Ln.10000@VoipTalk - UK) to <sip:11@192.168.0.29:5060>
    16:18:16.649 [CM503012]: Inbound any hours rule (main number) for 10000 forwards to DN:11
    16:17:26.089 [CM503003]: Call(10): Call to sip:11@192.168.0.29:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.0.10:5060
    16:17:25.894 [CM503008]: Call(10): Call is terminated
    16:17:25.664 [CM505001]: Ext.11: Device info: Device Identified: [Man: Aastra;Mod: 5x series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [Aastra 53i/2.5.0.82] PBX contact: [sip:11@192.168.0.29:5060]
    16:17:25.662 [CM503002]: Call(10): Alerting sip:11@192.168.0.10:5060;transport=udp
    16:17:25.321 [CM503025]: Call(10): Calling Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:17:25.268 [CM503004]: Call(10): Route 1: Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:17:25.266 [CM503010]: Making route(s) to <sip:11@192.168.0.29:5060>
    16:17:25.262 [CM505003]: Provider:[VoipTalk - UK] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [voip] PBX contact: [sip:844267727@93.152.95.165:5060]
    16:17:25.258 [CM503001]: Call(10): Incoming call from 07734104281@(Ln.10000@VoipTalk - UK) to <sip:11@192.168.0.29:5060>
    16:17:25.114 [CM503012]: Inbound any hours rule (main number) for 10000 forwards to DN:11
    16:12:04.901 [CM504004]: Registration succeeded for: 10000@VoipTalk - UK
    16:12:04.627 [CM504003]: Sent registration request for 10000@VoipTalk - UK
    16:12:04.267 [CM504004]: Registration succeeded for: 10000@VoipTalk - UK
    16:12:03.995 [CM504003]: Sent registration request for 10000@VoipTalk - UK
    16:10:23.857 [CM503003]: Call(9): Call to sip:11@192.168.0.29:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.0.10:5060
    16:10:23.603 [CM503008]: Call(9): Call is terminated
    16:10:17.939 [CM505001]: Ext.11: Device info: Device Identified: [Man: Aastra;Mod: 5x series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [Aastra 53i/2.5.0.82] PBX contact: [sip:11@192.168.0.29:5060]
    16:10:17.937 [CM503002]: Call(9): Alerting sip:11@192.168.0.10:5060;transport=udp
    16:10:17.659 [CM503025]: Call(9): Calling Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:10:17.614 [CM503004]: Call(9): Route 1: Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:10:17.612 [CM503010]: Making route(s) to <sip:11@192.168.0.29>
    16:10:17.610 [CM505001]: Ext.10: Device info: Device Identified: [Man: Yealink;Mod: T28;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T28P 2.51.23.5] PBX contact: [sip:10@192.168.0.29:5060]
    16:10:17.607 [CM503001]: Call(9): Incoming call from Ext.10 to <sip:11@192.168.0.29>
    16:10:07.341 [CM503003]: Call(8): Call to sip:10@192.168.0.29 has failed; Cause: 487 Request Terminated; from IP:192.168.0.9:5062
    16:10:07.164 [CM503008]: Call(8): Call is terminated
    16:09:58.677 [CM505001]: Ext.10: Device info: Device Identified: [Man: Yealink;Mod: T28;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T28P 2.51.23.5] PBX contact: [sip:10@192.168.0.29:5060]
    16:09:58.676 [CM503002]: Call(8): Alerting sip:10@192.168.0.9:5062
    16:09:57.883 [CM503025]: Call(8): Calling Ext:Ext.10@[Dev:sip:10@192.168.0.9:5062]
    16:09:57.835 [CM503004]: Call(8): Route 1: Ext:Ext.10@[Dev:sip:10@192.168.0.9:5062]
    16:09:57.834 [CM503010]: Making route(s) to "10"<sip:10@192.168.0.29:5060>
    16:09:57.832 [CM505001]: Ext.11: Device info: Device Identified: [Man: Aastra;Mod: 5x series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [Aastra 53i/2.5.0.82] PBX contact: [sip:11@192.168.0.29:5060]
    16:09:57.829 [CM503001]: Call(8): Incoming call from Ext.11 to "10"<sip:10@192.168.0.29:5060>
    16:09:20.509 [CM503003]: Call(7): Call to sip:11@192.168.0.29:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.0.10:5060
    16:09:20.305 [CM503008]: Call(7): Call is terminated
    16:09:20.032 [CM503025]: Call(7): Calling Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:09:19.982 [CM503004]: Call(7): Route 1: Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:09:19.980 [CM503010]: Making route(s) to <sip:11@192.168.0.29:5060>
    16:09:19.977 [CM505003]: Provider:[VoipTalk - UK] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [voip] PBX contact: [sip:844267727@93.152.95.165:5060]
    16:09:19.972 [CM503001]: Call(7): Incoming call from 07734104281@(Ln.10000@VoipTalk - UK) to <sip:11@192.168.0.29:5060>
    16:09:19.826 [CM503012]: Inbound any hours rule (01273735188) for 10000 forwards to DN:11
    16:08:59.962 [CM503003]: Call(6): Call to sip:11@192.168.0.29:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.0.10:5060
    16:08:59.769 [CM503008]: Call(6): Call is terminated
    16:08:59.488 [CM503025]: Call(6): Calling Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:08:59.442 [CM503004]: Call(6): Route 1: Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:08:59.440 [CM503010]: Making route(s) to <sip:11@192.168.0.29:5060>
    16:08:59.435 [CM505003]: Provider:[VoipTalk - UK] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [voip] PBX contact: [sip:844267727@93.152.95.165:5060]
    16:08:59.431 [CM503001]: Call(6): Incoming call from 07734104281@(Ln.10000@VoipTalk - UK) to <sip:11@192.168.0.29:5060>
    16:08:59.281 [CM503012]: Inbound any hours rule (01273735188) for 10000 forwards to DN:11
    16:06:28.539 [CM503003]: Call(5): Call to sip:11@192.168.0.29:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.0.10:5060
    16:06:28.324 [CM503008]: Call(5): Call is terminated
    16:06:28.311 [CM505001]: Ext.11: Device info: Device Identified: [Man: Aastra;Mod: 5x series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [Aastra 53i/2.5.0.82] PBX contact: [sip:11@192.168.0.29:5060]
    16:06:28.310 [CM503002]: Call(5): Alerting sip:11@192.168.0.10:5060;transport=udp
    16:06:28.010 [CM503025]: Call(5): Calling Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:06:27.993 [CM503004]: Call(5): Route 1: Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:06:27.991 [CM503010]: Making route(s) to <sip:11@192.168.0.29:5060>
    16:06:27.988 [CM505003]: Provider:[VoipTalk - UK] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Asterisk PBX] PBX contact: [sip:844267727@93.152.95.165:5060]
    16:06:27.983 [CM503001]: Call(5): Incoming call from 07734104281@(Ln.10000@VoipTalk - UK) to <sip:11@192.168.0.29:5060>
    16:06:27.844 [CM503012]: Inbound any hours rule (01273735188) for 10000 forwards to DN:11
    16:06:04.280 [CM503003]: Call(4): Call to sip:11@192.168.0.29:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.0.10:5060
    16:06:04.075 [CM503008]: Call(4): Call is terminated
    16:06:03.804 [CM503025]: Call(4): Calling Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:06:03.766 [CM503004]: Call(4): Route 1: Ext:Ext.11@[Dev:sip:11@192.168.0.10:5060;transport=udp]
    16:06:03.763 [CM503010]: Making route(s) to <sip:11@192.168.0.29:5060>
    16:06:03.761 [CM505003]: Provider:[VoipTalk - UK] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [voip] PBX contact: [sip:844267727@93.152.95.165:5060]
    16:06:03.745 [CM503001]: Call(4): Incoming call from 07734104281@(Ln.10000@VoipTalk - UK) to <sip:11@192.168.0.29:5060>
    16:06:03.598 [CM503012]: Inbound any hours rule (01273735188) for 10000 forwards to DN:11
    16:05:58.392 [CM504004]: Registration succeeded for: 10000@VoipTalk - UK
    16:05:58.169 [CM504003]: Sent registration request for 10000@VoipTalk - UK
    16:05:57.713 [CM504004]: Registration succeeded for: 10000@VoipTalk - UK
    16:05:57.487 [CM504003]: Sent registration request for 10000@VoipTalk - UK
    16:05:38.137 [CM503003]: Call(3): Call to sip:10@192.168.0.29 has failed; Cause: 487 Request Terminated; from IP:192.168.0.9:5062
    16:05:37.060 [CM503008]: Call(3): Call is terminated
    16:05:36.793 [CM503025]: Call(3): Calling Ext:Ext.10@[Dev:sip:10@192.168.0.9:5062]
    16:05:36.733 [CM503004]: Call(3): Route 1: Ext:Ext.10@[Dev:sip:10@192.168.0.9:5062]
    16:05:36.731 [CM503010]: Making route(s) to <sip:10@192.168.0.29:5060>
    16:05:36.727 [CM505003]: Provider:[VoipTalk - UK] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Asterisk PBX] PBX contact: [sip:844267727@93.152.95.165:5060]
    16:05:36.722 [CM503001]: Call(3): Incoming call from 07734104281@(Ln.10000@VoipTalk - UK) to <sip:10@192.168.0.29:5060>
    16:05:36.581 [CM503012]: Inbound any hours rule (01273735188) for 10000 forwards to DN:10
    16:05:29.306 [CM504004]: Registration succeeded for: 10000@VoipTalk - UK
    16:05:29.094 [CM504003]: Sent registration request for 10000@VoipTalk - UK
    16:05:28.327 [CM504004]: Registration succeeded for: 10000@VoipTalk - UK
    16:05:28.087 [CM504003]: Sent registration request for 10000@VoipTalk - UK
    10,779
    286
    At first guess I would say it is a setting/configuration in your phones. Can you call successfully from one extension to another? What settings are you using for call forwarding? Is it just these two phones? Do you have others you can substitute?
  3. timbo_w
    Aug 18, 2011
    hi, just have these two phones, i can call internally fine and also outgoing calls are fine, when i ring the number is displayed on the phone for 1 second and then i get sent to voicemail on the phone calling in
  4. leejor
    10,779
    286
    To eliminate the phone(s) itself as the problem, you could try installing the 3CX softphone on a PC. See if it reacts the same way.
  5. nzebizz
    Aug 21, 2011
    I am also suddley getting this from external calls say doing blind transfer
    Internal calls to extension work fine
