Solved Incoming calls to multiple extensions
Discussion in '3CX Phone System - General' started by CTVtech, Feb 22, 2018.
  1. CTVtech
    Jan 22, 2018
    Hi I'm new to this!
    I'm trying to set up a 3cx system with @65 phones.
    What I cant figure out is how to set up incoming calls to multiple receptionist and to have there phones all ring at the same time and also let them have their own extensions.
    11,116
    329
  3. saqqara16
    Jan 13, 2016
    46
    7
  4. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
  5. CTVtech
    Jan 22, 2018
    Thank you all!, I did create a ring, but i found out my browser wouldn't let me see the ring group ext.
    it only showed me the first 9 extensions and wouldn't let me scroll down had to reboot and then they showed up...... Thanks for all your quick response's
  6. apostolis_3CX
    Nov 1, 2017
    149
    15
    Glad to be of help.
