Incoming calls to to specific line instead of group
Discussion in '3CX Phone System - General' started by Brian A, Feb 5, 2018.
  1. Brian A
    Jan 16, 2018
    I have been playing around with this and can't seem to find a solution, does anyone know how to execute this type of call flow?
    When the main line rings, it rings line 1, if a second call comes in it rings line 2, and if a 3rd call comes in rings line 3. The entire team should all be able to see line 1, 2 and 3 on their phones.
    We are using YeaLink T46s.
    10,375
    231
    You will have to provide additional information about your set up. Are you using SIP trunks, or a gateway? One trunk group? It sound as if you want to simulate a "key system", which can be done, in a way, depending on the sets features.
    What are you trying to achieve? Call scenarios?.
  3. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    106
    38
    A prioritised hunt ring group will do this. You won't have the visibility directly, but BLFs showing presence will do it.
