Solved incoming Cid manipulation possible?
Discussion in '3CX Phone System - General' started by route, Jan 5, 2017.
  1. route
    Dec 3, 2016
    13
    I want to add prefix before of callerid to incoming routes or trunk like below,
    "Company 1 - 05348887275"
    "Company 2 - 01005486468"
    10,368
    228
  3. route
    Dec 3, 2016
    13
    i know that page but no success..
    i tried :
    source Pattern : (.*)
    Replace pattern : Company 1 - (.*)
    when i dial caller id : Company 1 - (.*)
  4. mortenjorge
    Apr 1, 2015
    58
    11
    You're missing which parameter you are using.
    use /1
    You need to "tell" 3cx that it should use (.*) - Which is your Inc callerid.
    Company 1 - /1
  5. route
    Dec 3, 2016
    13
    can you tell me how to tell 3cx? which section
  6. mortenjorge
    Apr 1, 2015
    58
    11
    Replace pattern : Company 1 - /1
    when i dial caller id : Company 1 - 05348887275
  7. route
    Dec 3, 2016
    13
    no its not working
    its directly writes " Company 1 - /1" as caller id , removes number
  8. mortenjorge
    Apr 1, 2015
    58
    11
    Ohh. Sorry..
    Its \ not /
    Company 1 - \1
  9. route
    Dec 3, 2016
    13
    done! thanks
