Incoming Direct SIP Calls Fail with Authentication Error
Discussion in '3CX Phone System - General' started by ITWorks, Apr 17, 2008.
  1. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    3CX Phone System Version5.1.4393.0
    X-Lite Softphone Version 3.0
    I have configure 3CX and DNS per 3CX Support instructions, however incoming direct SIP calls fail since upgrading 3CX version unless I configure an extension ID and password in 3CX and configure the same on the remote softphone. This was not necessary prior to upgrading 3CX and is rather impractical in implementation.
    [CM102001]: Authentication failed for SipReq: INVITE user.name@192.168.137.33 tid=fb69d548f9339a49 cseq=INVITE contact=user.name@222.111.22.11:17990 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings.
    222.111.22.11 is the outside IP address of my VOIP gateway. I have tried various Source Identification settings for the gateway with no success. Should an incoming Direct SIP call be required to authenticate?
    Thanks, Mark
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Please try to set source identification rule to:
    Contact: Host/Port = Custom value 222.111.22.11:17990
  3. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    Thank you for the suggestion Archie. Yes I had tried that configuration but same results. Everything works fine as long as the outside phone is configured as an extension. Anything else fails with the authentication error. To help eliminate gateway problems I made calls within the LAN but from different subnets by dialing a SIP URI to the IP address of the 3CX server. Are incoming direct SIP URI calls working fine for everyone else? If so, I think my settings for Direct SIP calls set under General Settings are not actually taking affect and I may need to reinstall.
    Mark
  4. alexmex
    May 7, 2008
    Hello Mark, I´m actually having the same problem it was working on a previous version and just upgraded to 5.1. I tried different softphones and different network configurations but no luck.
    Regards
    Alex
  5. nateb
    Oct 19, 2007
    68
    that is the same error message i was getting.
  6. vale
    Nov 2, 2007
    9
    I am also having the same problem. I was looking at the DNS configuration on the support section and I think thats for outgoing direct sip calls only (correct me if I am wrong) so I left that alone. I just created a sub domain to my sbs server which re routes sip calls to my 3CX server. The calls from my softphone (SJPhone) seem to be reaching the server but I also get the authentication problem.
  7. archie
    3CX Support
    Aug 18, 2006
    1,299
    As you can see in bold selection - username is empty. In this case PBX will never authorize such INVITE. Username should be the same as your extension number.
    And to be treated as incoming direct SIP call you should address it to SIP ID, not extension number.
    So, if you have ext.208 - define a SIP ID for it (let say - 'vale'). After that if your invite has To: <sip:vale@sip.mydomain.co.uk> and sip.mydomain.co.uk is defined as your SIP Domain -- it will be accepted as Direct SIP call (without athentication at all).
  8. vale
    Nov 2, 2007
    9
    Hmmm in my General Settings -> Direct SIP Calls I have the domain set to sip.mydomain.co.uk
    On my sip phone I am typing James@sip.mydomain.co.uk
    The sip phone then dials and I am getting that authentication problem. How do I get my SIP ID into that username field like you mentioned? Is there something I have not done?
    EDIT: I have got it working now it would seem I was typing James with a lower case j hence why it was not authenticating. Thanks for your help.
  9. archie
    3CX Support
    Aug 18, 2006
    1,299
    In extension settings under 'Other options' you will find 'SIP ID' field. It should be filled with 'James' if that extension should receive direct SIP calls addressed as James@sip.mydomain.co.uk.
