incoming extension no answer, until second dialing
Discussion in '3CX Phone System - General' started by jmooo, Apr 16, 2015.
  1. jmooo
    Mar 11, 2015
    18
    Hello and Thanks
    newbie here....
    using 3cx cloud with sonicwall TZ205 and TZ100 firewall(s) spa504g, snom320, snom821
    New configuration 5 days "live". 3 different offices, with three different firewalls and WAN's.
    firewall checker OK
    using "stun" setting with static external IP
    Here's where I'd like to start: When calling from one extension to another on same LAN, all works as expected.
    When call from extension to a different WAN, first call does not ring, log shows "no answer" (voicemial
    if enabled). HOWEVER a second call made as soon as possible after failed call or even 30 minutes
    later (I have not timed this) rings and is answerable as expected.
    Trouble shooting the issue is harder because after the first call gets "no answer" then next call goes
    through. I believe the time interval before I can reproduce the problem is over an hour.
    extensions appear "green" before first call get's no answer
    How about a hint? or "the" answer...
  2. jmooo
    Mar 11, 2015
    18
    additional configuration
    ports opened for 3cx host and remote extensions: 5000-6000 udp and tcp 55000-54999 udp 3478 udp and tcp
    WAN IP addresses of all hosts opened to each other
    NO QoS or voip settings enabled on any firewall
    LAN to WAN access for 3cx cloud server has UDP setting inactivity timeout changed to 30 seconds rather than default of 300
    phones have registration timeout changed from 3600 seconds to 100 on snom's and 300 on spa504's
    phones have RTP port set to same and firewall(s) 55000-64999
  3. jmooo
    Mar 11, 2015
    18
    error should be 54000-64999 not 55000-54999
  4. leejor
    11,082
    324
    I would start by using Wireshark to determine where (what device?,) the Invite is being blocked. Does it reach the "far side" of the router at the called end?
    Are you using the 3CX SBC at some ends? Sets behind routers? Using VPN?
    If sets are simply behind a router/firewall, has each been assigned a unique port number?
  5. jmooo
    Mar 11, 2015
    18
    3cx standard is installed on 3cx_cloudserve, resides on google-VM.
    no SBC's
    no proxy's
    I'm not good enough with wireshark to get much, but might as well try
    DO YOU HAVE ANY REFERENCES FOR USING GOOGLE-VM WITH 3CX CLOUD_SERVER
  6. jmooo
    Mar 11, 2015
    18
    SOLVED
    changed windows-server host to allow all phone host IP inbound
    changed all phone, firewall and server RTP port range to same
    removed all stun and external IP settings from phones
    some of above probably unnecessary?
    http://www.3cx.com/forums/posting.php?mode=reply&f=1&t=41169#
