incoming fax from inPhonex
Discussion in '3CX Phone System - General' started by deluca, Dec 15, 2008.
  1. deluca
    Dec 15, 2008
    can the 3cx be configured to receive faxes directly from a provider such as inPhonex? not pass thru but to the fax server on a dedicated DID? if so what special settings are needed on the line config. i want the faxes to be sent to the 3cx and delivered to email.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    FAX feature should be works with VoIP gateways Only. eg Patton, AudioCode and etc ...... For VoIP provider should be not yet.
  3. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    This is unsupported, and untested...
    ...but to have SOME chance for this:
    1. VOIP Provider must be set to NOT "PBX Delivers Audio" (this will most probably have a large effect for normal voice calls - so you must check this combination)
    2. Firewall/NAT device must be able to forward signalling and media correctly
    3. VoIP Provider must be delivering FAX using T.38 protocol - any other codec will NOT work.
    Regards
    Kevin
