- Joined
- Nov 13, 2007
- Messages
- 73
- Reaction score
- 1
I'm trying to receive FAX through a PSTN line using an SPA3102 as PSTN gateway, but when the call came in it doesn't be routed to the FAX extension. This i the log:
13:21:50.145 [CM503008]: Call(10): Call is terminated
13:21:50.145 [CM503015]: Call(10): Attempt to reach <sip:[email protected]:5060;user=fax> failed. Reason: Not Found
13:21:50.145 [CM503014]: Call(10): No known route to target: <sip:[email protected]:5060;user=fax>
13:21:50.130 [CM503010]: Making route(s) to <sip:[email protected]:5060;user=fax>
13:21:50.130 [CM505002]: Gateway:[FAX] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.7(GW)] Transport: [sip:192.168.0.8:5060]
13:21:50.114 [CM503001]: Call(10): Incoming call from 10000@(Ln.10000@FAX) to <sip:[email protected]:5060;user=fax>
13:21:50.036 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to Fax:888
If I route the call to an extension or to a DR, it works correctly.
There's anyone that have suggestions?
