Incoming Faxes Failing
Discussion in '3CX Phone System - General' started by pogue1000, Jul 21, 2011.
  1. pogue1000
    Jun 1, 2011
    21
    Trying to get the 3cx fax server working on incoming and here is a snippet from my log.
    The error from my PSTN fax machine says "Busy"
    Now if i call my PSTN fax number from my cell phone i hear a beeping
    Just trying to get the faxes emailed to me, "nothing fancy".
    15:02:42.649 [CM503008]: Call(72): Call is terminated
    15:02:30.805 Currently active calls - 1: [72]
    15:01:58.805 Currently active calls - 1: [72]
    15:01:56.993 [CM503007]: Call(72): Device joined: sip:888@192.168.1.10:5100;user=phone
    15:01:56.977 [CM503007]: Call(72): Device joined: sip:aFs7x34333d@px1.nexvortex.com:5060
    15:01:56.977 [CM503002]: Call(72): Alerting sip:888@192.168.1.10:5100;user=phone
    15:01:56.805 [CM503025]: Call(72): Calling @[Dev:sip:888@192.168.1.10:5100;user=phone]
    15:01:56.774 [CM503004]: Call(72): Route 1: @[Dev:sip:888@192.168.1.10:5100;user=phone]
    15:01:56.774 [CM503010]: Making route(s) to <sip:888@192.168.1.10:5060;user=fax>
    15:01:56.758 [CM505003]: Provider:[NexVortex] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:aFs7x34333d@XX.XX.XXX.X:5060]
    15:01:56.758 [CM503001]: Call(72): Incoming call from +1XXXXXXXXXX@(Ln.10001@NexVortex) to <sip:888@192.168.1.10:5060;user=fax>
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Is your provider supporting T.38 fax ?
    3CX is supporting only T.38 fax to e-mail - this is most probably the reason.
    Regards
  3. pogue1000
    Jun 1, 2011
    21
    Yep, I use Nexvortex and I was told they are T38
  4. eagle2
    Apr 27, 2011
    1,085
    11
    Try searching the forums -- there was a recent post on the problem with faxes from Nexvortex.
    Regards
  5. eapugo
    Mar 3, 2011
    Bandwidth requirements for T.38 require the least latency in a connection. If you are using nexVortex, you usually have to request that a specific number gets pinned up for T.38 faxing. Sending a request to the support site usually gets a quick response.
  6. netswork
    netswork Active Member
    Mar 11, 2011
    577
    +1 to what Eapugo said. You have to email support@nexvortex.com with your account number and DID number and ask them to enable t.38 support. I have still had trouble making it work after that though.
  7. pogue1000
    Jun 1, 2011
    21
    Ok guys it is working!
    I had already confirmed my line was setup for t38. Nexvortex has great customer support FYI>
    But i followed this thread
    http://www.3cx.com/forums/fax-server-problem-solution-provided-18484.html
    Most importantly i changed a config file
    as said in one of the posts.
    Re: Fax server problem
    Postby nickybrg » Wed Jan 05, 2011 12:39 am
    You have to configure 3CX FAX SERVER for NAT. If you open the Fax cfg files there, there are comments that you need to uncomment and update.
    C:\ProgramData\3CX\Data\Fax\Cfg
    there are 2 files - open and read them. They should be self explanatory.
  8. smokeman
    Dec 10, 2010
    50
    I don't have this directory on v10, has it moved, or has this changed...I'm also having nexvortex fax problems.
  9. eagle2
    Apr 27, 2011
    1,085
    11
    What is your OS?
    The folder is in place. The path quoted applies for server OS.
    Regards
  10. smokeman
    Dec 10, 2010
    50
    appologies, I was looking in program files...
