Solved Incoming/missed calls appending 0
Discussion in '3CX Phone System - General' started by SVanBC, Feb 13, 2018.
  1. SVanBC
    Dec 14, 2017
    40
    Since a few weeks, or actually since we configured E164 Processing (we did this to be able to call our phone contacts through the 3CX iPhone client), we noticed that incoming calls would have a 0 appended. This is also the problem with missed calls.
    When we go to 'Missed' on our SNOM devices and recall them, it will call to (Belgium): 0011 12 34 56 instead of 011 12 34 56.
    This issue is on every client; Windows client, iPhone client, SNOM devices.
    When we dial 0032 or +32 (Belgium, our location) the calls will pass through. The E164 works as intended.
    I configured following settings at E164 Processing:
    [​IMG]
    Outbound rules are not configured:
    [​IMG]
    To give an example, this is what our call log looks like: *360525:unknown (0011360525)
    I'm lost in space.. :eek::eek::eek:
    I tried stripping a digit but then it only dials 11 12 34 56, unless it's prefixed with +32 or 0032
    It looks like it's some kind of incoming formatting? Not sure...
    If anyone has any clue where to find this issue?
    Thanks in advance!
    10,375
    231
    So.... the number as sent to you, has two leading zeros? You can format incoming CID, adding or stripping digits as needed. E164 should only affect the formatting of dialled (outgoing) numbers.
    https://www.3cx.com/docs/cid-reformatting/
    SVanBC likes this.
  3. SVanBC
    Dec 14, 2017
    40
    Well thanks! I totally forgot about the SIP trunks...
    FIX: There was a 0\1 replacer active on the trunk, removed it.
    I hope my 3CX certification in March will clear things out! ;-)
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Glad to hear the issue has been resolved and thank you for updating the thread with your solution
