Incoming MSN Mapping
Discussion in '3CX Phone System - General' started by Dida28, Aug 13, 2007.
  1. Dida28
    Aug 8, 2007
    9
    i use the 3cx with the Call Router from Patton 4552.
    The 3cx is connected with 2 PSTN Lines to ISDN.
    ISDN > Patton > 3cx
    All works fine now.
    But i don't now how can i map/route incoming calls from specific MSNs to specific extensions. I can only route a specific PSTN-line to a specific Extension in the 3xc-configuration interface.
    Is it possible to route MSNs to extensions?
    Thank you...
    Dida
  2. marcoluce
    Jun 22, 2007
    9
    Hi Dida,
    Try using "Add DID" on 3CX. You can then specify what incoming number from the PSTN is sent to what extension. The Patton will take care of "hiding" the fact that the line is a MSN line and not DID. Check the 3CX server status log to see in what format (how many digits, including prefix etc) the MSN number arrives at 3CX, then enter the number as DID on 3CX accordingly.
    -Marco
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    What is MSN line, btw :?:
  4. telis
    telis New Member
    Aug 13, 2007
    158
    28
    MSN stands for Multi Subscriber Numbering
    OK, first a bit of background.
    ISDN lines come in either bundles of 2 lines (called ISDN2e) or variable size bundles of 8 to 30 lines (called ISDN30).
    ISDN2e lines can come in two variants, Standard Access and System Access. The Standard variant is intended for connecting devices, like an ISDN modem, and/or a G5 fax machine (G5 faxes use ISDN). ISDN2e System lines are designed for connecting to a PBX.
    MSN is an ISDN feature a bit similar to another ISDN feature, DDI. MSN only works on ISDN2 when it is Standard mode and allows one 2 line bundle to have up to 9 extra phone numbers. This allows you to have 10 devices attached each with their own phone number. So you could have say 10 G5 fax machines sharing two lines, each with it's own incoming phone number and no need for a PBX. (you only get two sockets on the BT box, you'll need an inexpensive adapter to expand this number to 10).
    DDI performs the same role but you can have a pretty much unlimited number of phone numbers and these can span multiple ISDN bundles, so you could have 20 phones numbers over 3 ISDN2e bundles, or even 200 phone numbers over 6 ISDN30 bundles. The diadvantage is that in order for this to work you need a PBX (or equivalent like a ISDN/SIP gateway) to route the calls.
    Hope this helps.
  5. Dida28
    Aug 8, 2007
    9
    Thanks for your replies.
    now i'm sure, that i have a bundle of 2 lines (called ISDN2e).
    We have 1 "Main-Number" an 9 extra phonenumbers on this port.
    I tryed to map with the Patton 4552 the incoming calls from specific MSN to a specific with following function (MSN 916313 -> ext. 101):
    Code:
    mapping-table called-e164 to called-e164 MAP_MSN_2_SIP
        map 916313 to 101
    The other way arround it works fine. Outgoing calls will correctly assigned to the extensions with this function:
    Code:
    mapping-table calling-e164 to calling-e164 MAP_SIP_2_MSN
    map 101 to 916313
        map 102 to 916313
    In the log of the 3cx i see independent from different configuration
    (and i tryed a lot of things) always the ext. of the patton PSTN line (10001)
    Code:
    19:45:39.415 CallConf::onIncoming [CM103002] Call(41): Incoming call from 0891576495 (Ln:10001@Patton ISDN) to sip:10001@192.168.178.41
    here is my configuration file of the Patton SN4552
    Code:
    context cs switch
      national-prefix 0
      international-prefix 00
      routing-table called-e164 RT_SPEED_DIAL
        route T dest-table RT_NR_BLOCKING MT_SPEED_DIAL
      routing-table called-e164 RT_NR_BLOCKING
        route default dest-table RT_CALL_ROUTING MT_SET_CNPN
      routing-table called-e164 RT_CALL_ROUTING
        route default dest-interface ISDN0 MAP_SIP_2_MSN
      routing-table called-e164 RT_INCOMING
        route default dest-interface SIPIF0 MAP_MSN_2_SIP
      mapping-table called-e164 to called-e164 MT_SPEED_DIAL
      mapping-table calling-e164 to calling-e164 MT_SET_CNPN
      mapping-table called-e164 to called-e164 MT_NR_TRANSLATION
        map 101 to 916313
        map 102 to 916313
        map 916313 to 101
      interface isdn ISDN0
        route call dest-table RT_INCOMING
      interface isdn ISDN1
        route call dest-interface SIPIF1
      interface isdn IF_S0_01
      interface sip SIPIF0
        bind gateway SIPGW0
        service default
        route call dest-table RT_CALL_ROUTING
        remote-party-id called-party
        address-translation outgoing-call to-header user-part fix 10001 host-part interface
        address-translation incoming-call called-e164 remote-party-id-header
      interface sip SIPIF1
        bind gateway SIPGW1
        service default
        route call dest-interface ISDN1
        address-translation outgoing-call to-header user-part fix 10002 host-part interface
        address-translation incoming-call called-e164 request-uri
      interface sip IF_SIP_SERVICE
        service default
      service hunt-group SER_HG_PSTN_FALLBACK
        timeout 6
        drop-cause normal-unspecified
        drop-cause no-circuit-channel-available
        drop-cause network-out-of-order
        drop-cause temporary-failure
        drop-cause switching-equipment-congestion
        drop-cause access-info-discarded
        drop-cause circuit-channel-not-available
        drop-cause resources-unavailable
        drop-cause no-route-to-destination
        route call 1 dest-interface IF_S0_00
        route call 2 dest-interface IF_SIP_SERVICE
    context cs switch
      no shutdown
    gateway sip SIPGW0
      bind interface IF_IP_LAN router
      service default
        domain 192.168.178.41
        authentication 10001 password dZ8edXkjFnM= encrypted default
        default-server 192.168.178.41 loose-router
        registration-lifetime 120
        registrar 192.168.178.41
        user 10001
    gateway sip SIPGW0
      no shutdown
    gateway sip SIPGW1
      call-signaling-port 5062
      service default
        authentication 10002 password iAaKwKfxX4Q= encrypted default
        user 10002
    gateway sip SIPGW1
      no shutdown
  6. marcoluce
    Jun 22, 2007
    9
    Hi Dida,
    Your configuration fixes the user part of the TO-Header to be 10001 (the line ID):
    Code:
    Please change this to
    Code:
    address-translation outgoing-call request-uri user-part fix 10001 host-part to-header target-param none
    Make sure the old address-translation gets removed (edit the file off-line and download the config, or first remove the old address-translation). This fixes the Request URI to the line ID (3CX will still recognize the line based on this), and the TO-Header remains to be the "101" that you configured on the SmartNode.
    Still, I believe that you could also directly configure the MSN number (916313) as DID on the 3CX.
    Hope this helps
    -Marco
  7. Dida28
    Aug 8, 2007
    9
    Hi Marco!
    This was the solution of my problem. Now it works fine, thank you very much! :lol: :D :lol:
    Nice greeting from Germany near Munich,
    Dida
