- Joined
- Feb 1, 2008
- Messages
- 3
- Reaction score
- 0
Hi all,
I have version 5.0.3790.0 of the 3cx server and I am excperiencing some weirdness with my broadvoice connection. I can call internally with no issues, and i can recieve incoming calls, I currently have the 1.65 sj phone setup as a test until my hard phones arrive.I am getting the dreaded "CM503003]: Call(26): Call to sip:[email protected] has failed; Cause: 403 Forbidden; from IP:147.135.12.221" I have a generic verizon westel DSL modem with all the udp ports directly forwarded to my 3cx server, i am not running any firewall rules etc. just vanilla NAT with the UDP's pointed directly at my server. I do the firewall test and get the 8 and 10 warnings.
thanks!
21:30:58.562 Call::Terminate [CM503008]: Call(51): Call is terminated
21:30:58.515 Call::RouteFailed [CM503014]: Call(51): Attempt to reach [sip:[email protected]] failed. Reason: Forbidden
21:30:58.515 CallLeg:nFailure [CM503003]: Call(51): Call to sip:[email protected] has failed; Cause: 403 Forbidden; from IP:147.135.12.221
21:30:58.171 CallLeg:nFailure [CM503003]: Call(51): Call to sip:[email protected] has failed; Cause: 403 Forbidden; from IP:147.135.12.221
21:30:57.859 CallCtrl:nSelectRouteReq [CM503004]: Call(51): Calling: VoIPline:10000@[Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060]
Jeremy
thanks!
Jeremy
