Incoming Route
Discussion in '3CX Phone System - General' started by techs221, Feb 13, 2017.
  1. techs221
    Feb 8, 2017
    18
    Hello All
    I have my sip trunk setup and I can call out from my phone, but I can not receive any incoming calls at all.
    I have an incoming route coming in to a call group nothing happens, I also tried to an extension as well with nothing.
    Any help getting the incoming route working would be great thanks
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi techs,
    Did you run the firewall checker? Please run the firewall checker and let us know if it passed.
  3. techs221
    Feb 8, 2017
    18
    Ok it tells me that the port forwarding is not configured these are the ports I have configured for the server
    tcd/udp 5060-6000
    UDP 9000-6900
    TCP 80
    TCP 443
    id there a different port I need to be forwarding for the incoming to work right
  4. GiannosC_3CX
    GiannosC_3CX Guest
  5. techs221
    Feb 8, 2017
    18
    I have forward all of the right ports and the firewall checker is still failing but I can get to my server from outside the lan
  6. leejor
    10,779
    286
    Does the 3CX Activity log actually show the incoming call, is it getting that far?
  7. techs221
    Feb 8, 2017
    18
    No I do not have anything in my activity log at all
  8. techs221
    Feb 8, 2017
    18
    these are all the ports I have pointed to my server
  9. techs221
    Feb 8, 2017
    18
    Also I was using Elastix phone server prior and that was working good so I am not sure why this wouldn't be working
  10. leejor
    10,779
    286
    Is registration successful? Can your provider confirm that they have the correct information to route calls to you?
  11. techs221
    Feb 8, 2017
    18
    Yes registration is successful and I can make calls just fine I just can't get any calls coming in
  12. GiannosC_3CX
    GiannosC_3CX Guest
    Hi tech221,
    I have sent you p.m.
