Incomming Call Rejected
Discussion in 'Windows' started by wlt7913c, Jul 11, 2010.
  1. wlt7913c
    Jul 11, 2010
    I just downloaded and installed the Free version of the PBX and I am testing it using the 3CX softphones. I have one internal to my network and one external to the network; 100 is within the network, and 101 is outside the network (external). I can call 101 from 100 it rings connects etc. no problem. However I cannot do the reverse. When I try to call from 101 to 100 the call fails. on the 3CX Debug screen it simply says "Forbidden" on the server...
    15:50:34.674 [CM502001]: Source info: From: <sip:101@209.168.218.58:5060>;tag=4126b139<sip:100@209.168.218.58:5060>
    15:50:34.674 [CM503013]: Call(8): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 100@192.168.25.59:5060 tid=941be70d505b0153 cseq=INVITE contact=101@97.67.154.83:65385 / 1 from(wire)
    15:49:08.900 [CM502001]: Source info: From: <sip:101@209.168.218.58:5060>;tag=8757fd2c<sip:100@209.168.218.58:5060>
    15:49:08.890 [CM503013]: Call(7): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 100@192.168.25.59:5060 tid=bd2a2a2f516c134e cseq=INVITE contact=101@97.67.154.83:65385 / 1 from(wire)
    15:48:37.165 [CM504001]: Ext.101: new contact is registered. Contact(s): [sip:101@97.67.154.83:65385/101]
    Can someone tell me why this happened and perhaps how to fix it?
    11,285
    360
    What I would suspect is that you don't have STUN enabled on the remote extension. When it registers 3CX should see the port number to be something like 5060, not 65385
  3. wlt7913c
    Jul 11, 2010
    According to the advanced settings in the softphone STUN is enabled and using the 3x site.
  4. leejor
    11,285
    360
    I'm seeing IP addresses that don't seem right. 97.67.154.83 looks like the remote extensions public IP, which is fine. You should not be seeing other IP's that begin with 209.168 and some with 192.168. I'm going to assume that the IP's with 192.168.XX.XX are on your local LAN. Where are the 209.168.XX.XX coming from? Is that the internal LAN range from the remote site?
    When Ext 101 registers it does so with the public IP and a port (65385) but the Source shows a private IP and port 5060.
