Incomming calls end after short times
Discussion in '3CX Phone System - General' started by sonlm, Oct 1, 2007.
  1. sonlm
    Mar 28, 2007
    13
    I have 3CX used with Linksys SPA-3102. Everything went ok but that:
    When it has an incomming call, the conversation was sometimes stopped halfway (after about 15-20s or maybe longer) and sometimes finished well. It is not stable.
    What's the reason and tell me somethings to do.
    Thanks and regards,
    Sonlm
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Heya, make sure that on the PSTN line you have the "PSTN detect long silence" you have it set to No, so that the line wont disconect if it detects any silence(sometime doesnt need to detect silence to disconnect).
    Cheers
  3. Ryandc
    Aug 13, 2007
    70
    You need to post your logs if you're dropping calls so we can determine if it's your phone, the remote end, or a gateway device that's sending the disconnect signal.
    If you're getting a "hangup from wrong leg has arrived" message ANYWHERE in your logs, then your NAT traversal isn't working, possibly due to STUN or other probs. Bind your Gateway to your PBX.
    But, in this case, logs would help out. A lot.
  4. sonlm
    Mar 28, 2007
    13
    Following is my server log with 1 dropping call:
    It looks like a bit confusion :)
    I think it's my gateway which sending the disconnect signal.
    I set "Detect PSTN long silence" to YES and "PSTN long silence duration" is 15. But even when it's set to NO, calls still interrupted.
  5. Ryandc
    Aug 13, 2007
    70
    You can ignore all that STUN server stuff. Basically, the problem is here:
    14:46:30.187 StratLink::eek:nHangUp [CM104001] Call(7): Ln:10000@SPA-3102 hung up call; cause: BYE; from IP:10.0.0.60
    Whatever device you're using at 10.0.0.60 is sending a "BYE" without it being requested by either party. You're right in looking at the PSTN long silence detection. Make sure you're using current firmware for whatever device it is.
    14:45:57.187 CallLegImpl::eek:nConnected [CM103001] Call(7): Created audio channel for Ext.102 (10.0.0.61:10010) with third party (10.0.0.60:16422)
    14:45:57.171 StratInOut::eek:nConnected [CM104005] Call(7): Setup completed for call from Ln:10000@SPA-3102 to Ext.102
    14:45:57.171 CallLegImpl::eek:nConnected [CM103001] Call(7): Created audio channel for Ln:10000@SPA-3102 (10.0.0.60:16422) with third party (10.0.0.61:10010)
    14:45:48.828 CallConf::eek:nProvisional [CM103003] Call(7): Ext.102 is ringing
    14:45:48.187 CallConf::eek:nIncoming [CM103002] Call(7): Incoming call from 047152098 (Ln:10000@SPA-3102) to sip:10000@10.0.0.54:5060
