Incomming calls fail; Device Not Identified error
Discussion in '3CX Phone System - General' started by MikeMSTG, Oct 21, 2014.
  1. MikeMSTG
    Oct 21, 2014
    Incoming phone calls are getting this error message:
    21-Oct-2014 14:17:39.834 [CM505003]: Provider:[Broadvox Fusion (IP Based) - US] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:xxxxxxxxxx@xxx.xxx.xxx.xxx:5060]
    The caller will hear "call transfer failed" message.
    The odd part is this typically only happens after a longer period of time of no phone calls. If I were to make an outgoing phone call and then receive one, no problem.
    We are configured with a direct IP so we do not require in/out registration. I have configured Source identification by DID. I am on the latest and greatest version of 3cx.
    Anyone know why this is happening?
    10,861
    301
    I seem to recall seeing
    often, even on working calls. So...I'm not sure that is the issue. I think that additional logs are needed, something showing an error, or call rejection.
  3. MikeMSTG
    Oct 21, 2014
    Here is the full log of the call:
    22-Oct-2014 11:32:31.856 [CM505003]: Provider:[Broadvox Fusion (IP Based) - US] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:xxxxxxxxxx@xxx.xxx.xxx.xxx:5060]
    22-Oct-2014 11:32:31.856 Leg L:2.3[Extn] is terminated: Cause: 503 No matching transport found/INVITE from local
    22-Oct-2014 11:32:31.856 L:2.1[Line:10000<<xxxxxxxxxx] failed to reach Extn:1234, reason Server Failure
    22-Oct-2014 11:32:31.856 Call to T:Extn:1234@[Dev:sip:1234@192.168.xxx.xxx:5060] from L:2.1[Line:10000<<xxxxxxxxxx] failed, cause: Cause: 503 No matching transport found/INVITE from local
    22-Oct-2014 11:32:31.856 [CM503003]: Call(C:2): Call to <sip:1234@192.168.xxx.xxx:5060> has failed; Cause: 503 No matching transport found/INVITE from local
    22-Oct-2014 11:32:31.756 [CM503025]: Call(C:2): Calling T:Extn:1234@[Dev:sip:1234@192.168.xxx.xxx:5060] for L:2.1[Line:10000<<xxxxxxxxxx]
    22-Oct-2014 11:32:31.703 [CM503027]: Call(C:2): From: Line:10000<<xxxxxxxxxx ("Main Number:xxxxxxxxxx" <sip:xxxxxxxxxx@192.168.xxx.xxx:5060>) to T:Extn:1234@[Dev:sip:1234@192.168.xxx.xxx:5060]
    22-Oct-2014 11:32:31.703 [CM503004]: Call(C:2): Route 1: from L:2.1[Line:10000<<xxxxxxxxxx] to T:Extn:1234@[Dev:sip:1234@192.168.xxx.xxx:5060]
    22-Oct-2014 11:32:31.703 [CM505003]: Provider:[Broadvox Fusion (IP Based) - US] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:xxxxxxxxxx@xxx.xxx.xxx.xxx:5060]
  4. leejor
    10,861
    301
    Well this is the problem...
    I'm not certain if is is a network (UDP/TCP) setting (Codec?).
    Did this just start, or did you make some changes.
    I thought this sounded familiar... http://www.3cx.com/forums/cisco-spa504g-always-busy-or-not-available-38654-s15.html
  5. MikeMSTG
    Oct 21, 2014
    Same issue...never got anywhere with it.
    We checked the network setup and all was clear. We also contacted our provider and confirmed that the calls are connecting to our side without issue. As best I can tell, the issue is with 3cx, whether it be setup or phone support, it is most likely on the PBX side.
  6. leejor
    10,861
    301
    An intermittent problem is the worst thing to troubleshoot. Do you have any other VoIP providers, or have you ever used any other VoIP providers that this has, or has not, happened on?
    The best you could probably hope for is another user that has the same provider, and can provide trunk settings to compare with.
    Hopefully one that isn't having the same issue.
    You could delve a bit deeper using Wireshark. There may also be some additional, helpful, information if you use the verbose logs setting.
