Incomming calls Ring Ext but drop b4 VM
Discussion in '3CX Phone System - General' started by MikeSr, Feb 3, 2007.
  1. MikeSr
    Jan 23, 2007
    27
    Call come in through the GXW4104 Ring the extention either directly by numberic entry or via call transfer via DR. But before it gets a chance to go to VM if disconnects and drops the line. Here is the Server Status message of this sequence:
    13:42:52.796 StratInOut::eek:nCancel: Call from Ln:10000@GXW4104 to Ln:10000@GXW4104 has been terminated
    13:42:52.562 >>: Can't provideOffer when not in Connected state
    13:42:46.593 StratInOut::eek:nAnswered: Call from Ln:10000@GXW4104 is answered on Ext.120
    13:42:34.921 CallConf::eek:nIncoming: Incoming call from Ln:10000@GXW4104 to sip:10000@192.168.1.99
    Any Ideas ?
  2. MikeSr
    Jan 23, 2007
    27
    a bit more info, If the Ext is set to ring for 6 secs and then goto VM if no answer. the following is true:
    IF EXT is registered then call is dropped after the preset period .
    IF the Ext is not registered and the Setting for Phone Unregistered is set to go to VM. That Works.
    Not sure what path to follow, but it seems like a software issue.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,916
    225
    Unfortunately this is an issue with the Grandstream gateways. They expect a response from the phone system within 30 seconds.
    To work around this, route all inbound calls to a digital receptionist, and then have the user go to the correct extension from there.
    We are looking in to this and will log a support request at Grandstream
