incomplete dial number
Discussion in '3CX Phone System - General' started by woogy, May 9, 2007.
  1. woogy
    May 9, 2007
    I have Grandstream GXW4104 connected to the 3CX, Each time I dial a local number I receive a message that the number I am dialing is incomplete. The outbound rule that I am using is 9 with one r. Any idea
  2. brianfpmoab
    Mar 15, 2007
    17
    woogy,
    Can you post the messages in the server status page when you get this error.
    It should look something like this
    13:54:55.328 StratInOut::eek:nConnected Call(C:4): Setup completed for call from Ext.301 to Ln:30001@PA
    13:54:55.328 CallLegImpl::eek:nConnected Call(C:4): Created audio channel for Ext.301 (70.96.174.45:16412) with third party (70.96.174.34:6000)
    13:54:52.187 CallConf::eek:nProvisional Call(C:4): got response from 15708885272
    13:54:51.671 CallConf::eek:nIncoming Call(C:4): Incoming call from Ext.301 to sip:315708885272@70.96.174.138
    That is a completed call on my system with an outbound rule to remove the first number. The rule is 3 and one r.
    With your messages we should be able to help you better.
    Brian
  3. Anonymous
    Anonymous Guest
    Also,
    Have you bound the outbound rule to a gateway?
    For the local numbers try to dial the full number that includes the area code.
  4. NigelG
    Mar 29, 2007
    48
    As Henk says, if you are using a VOIP provider then the number will not be "local" to their gateway annd probably needs the full code and number.
    Rgds
    NigelG
