INCONVENIENCE outgoing Calls With PSTN Line
Discussion in '3CX Phone System - General' started by codigit, Oct 2, 2007.
  1. codigit
    Mar 1, 2007
    25
    Hello, look i have a inconvenience with PSTN line in the outgoing calls, when i make a call trought the PSTN LINE just RING one time after that Stop and looks like in the air...
    I dont know what can be but i need to fix it as soon as possible...
    All is ok i receive the calls good trought the pstn but can go out, before install this in the oficce i prove this in my house and is ok, i was thinking maybe for going out calls trought pstn i have to open ports>??
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Can you post a log of what's happening from 3CX? Might help. What PSTN gateway are you using?
  3. codigit
    Mar 1, 2007
    25
    Im using PAP2-3000
    I cant send you know a reply of the 3cx logs, but look fine normal as well... but just ring one time after that just looks in the air the comunication..
    im using a SPA-3000
