Inconvenience Registering VOIP LIne
Discussion in '3CX Phone System - General' started by codigit, Oct 2, 2007.
  1. codigit
    Mar 1, 2007
    25
    Hey i have a little inconvenince the voip provider lines are not registering, i dont know what can be wrong, say somehting like the STUN inconvenience and mention firewalls too, i will post a little things of the log.... i have 4 voip providers and the calls are going out but llook like are not registered
    20:59:44.831 ExtLine::Register [CM010002] Line DN='10004' device='VOIPProvider4' can not be registered. External IP isn't resolved.
    20:59:44.831 ExtLine::Register [CM110001] Use External IP for device line registration DN='10004' device='VOIPProvider4'
    20:59:44.831 ExtLine::Register [CM010002] Line DN='10001' device='VOIPProvider1' can not be registered. External IP isn't resolved.
    20:59:44.831 ExtLine::Register [CM110001] Use External IP for device line registration DN='10001' device='VOIPProvider1'
    20:59:44.831 ExtLine::Register [CM010002] Line DN='10003' device='VOIPProvider3' can not be registered. External IP isn't resolved.
    20:59:44.831 ExtLine::Register [CM110001] Use External IP for device line registration DN='10003' device='VOIPProvider3'
    20:59:44.781 ExtLine::Register [CM010002] Line DN='10002' device='VOIPProvider2' can not be registered. External IP isn't resolved.
    20:59:44.781 ExtLine::Register [CM110001] Use External IP for device line registration DN='10002' device='VOIPProvider2'
    20:59:40.986 CallMgr::failResolveExtIp [CM200001] Failed to resolve external IP!
    20:59:40.986 StunClient::process [CM215001] STUN failed to resolve external IP using server 64.69.xx.xx
    20:59:37.951 StunClient::process [CM215001] STUN failed to resolve external IP using server 64.69.xx.xx
    20:59:34.897 StunClient::process [CM115001] Send initial STUN request to 64.69.xx.xx
    20:59:34.897 StunClient::process [CM215001] STUN failed to resolve external IP using server 64.69.xx.xx
    20:59:31.803 StunClient::process [CM215001] STUN failed to resolve external IP using server 64.69.xx.xx
    20:59:28.788 StunClient::process [CM115001] Send initial STUN request to 64.69.xx.xx
    20:59:28.678 StunClient::process [CM215001] STUN failed to resolve external IP using server 64.69.xx.xx
    20:59:25.664 StunClient::process [CM215001] STUN failed to resolve external IP using server 64.69.xx.xx
    20:59:22.529 StunClient::process [CM115001] Send initial STUN request to 64.69.xx.xx
    20:59:22.429 StunClient::process [CM215001] STUN failed to resolve external IP using server 64.69.xx.xx
    20:59:19.345 StunClient::process [CM215001] STUN failed to resolve external IP using server 64.69.xx.xx
    20:59:15.329 StunClient::process [CM115001] Send initial STUN request to 64.69.xx.xx
    PLEASE HELP ME WITH THIS>>THANKS
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I just had this myself. I restarted the 3CX services and all was well again. Not sure what happened.
    How many lines do you have? You have 4 VOIP lines listed here. How many PSTN lines do you have?
  3. codigit
    Mar 1, 2007
    25
    I just have 1 pstn line
    I think the inconvenience is with the port of the router, i have to open i really dont know im confused about, it was working great in my house but when i installed in the office is not registering the line..
    Im using 2 pap2 and 1 SPA-3000 so i have 5 extension and 1 pstn line..
    Thats all and the calls are going out great trought the voip system but looks like are not registering the line.. and i restart the system many times
  4. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Have you opened every single port on your router needed for 3CX to work?
    I have like this
    Port opened: 3478 TCP and UDP
    5060 TCP and UDP
    9000-9020 UDP
    Cheers
