Solved Incorrect link for Android client in email from 3CX V15.5 sp2 beta
Discussion in 'Android' started by sip.bg, Nov 14, 2017.
  1. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    There is something wrong with the email sent by 3CX V15.5 sp2 beta: Clicking on the link provided for downloading 3CX client for Android results in error after provisioning: Incompatible version of the client.
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    13
    What version of 3CXPhone for Android are you currently running ?
    Thank you
  3. sip.bg
    Nov 7, 2016
    704
    220
    I'm awaiting answer from the customer.
    For me the link is loading a beta version -- 15.5.146, as I've subscribed for beta, but for him -- obviously another version.
  4. sip.bg
    Nov 7, 2016
    704
    220
  5. Marios Neophytou
    Mar 1, 2016
    258
    13
    Can you ask your customer if he touched the User-Agent on the PBX parameters?
    Thank you
  6. sip.bg
    Nov 7, 2016
    704
    220
    No, I don't think so (he is just an user).
    I've upgraded the PBX from v14 few days ago.
    These are the user agent settings, I think they are default ones:
  7. sip.bg
    Nov 7, 2016
    704
    220
    The customer replied that installed version is 15.1.90 -- the one from Google Play (following the link from email).
  8. Marios Neophytou
    Mar 1, 2016
    258
    13
    Uninstall/Install the app and try again please
    Thank you
    #8 Marios Neophytou, Nov 14, 2017
  9. sip.bg
    Nov 7, 2016
    704
    220
    The new client 15.5.157 works normally.
    Waiting for SP3 hoping other issues to be solved.
  10. Marios Neophytou
    Mar 1, 2016
    258
    13
    Hello @sip.bg,
    Glad to hear that.
    Thank you
