Increase Hard Drive Capacity
Discussion in '3CX Phone System - General' started by ck1, Feb 23, 2018.
  1. ck1
    ck1
    May 5, 2016
    6
    I have a situation where im running a VPS and am needing to increase hard drive space. i upgraded my vps to a larger hard drive. is there a way to get 3cx to recognize the new hard drive size or do you have to reinstall?
  2. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    There is no need for reinstalling the PBX.
    If this is the same VPS, Shutdown VPS increase HD and power up VM, after that check the Dashboard; System Settings; Disk Usage.
    If you are moving 3CX from one VPS to antoher then backup your 3cx config and restore it on that new VPS
    apostolis_3CX likes this.
  3. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    Gparted.org. Free utility for expanding Linux and Windows partitions without data loss.
  4. ck1
    ck1
    May 5, 2016
    6
    Did not work for me, any code you have to run when it boots up?
